'05 Vibe - how change coolant
Posted: Sun Oct 04, 2009 6:36 am
by bbdad57
Is there a pitcock on the raditor to drain it - also is there any other bleeder plugs I need to open to fully drain the system.Thanks
Re: '05 Vibe - how change coolant (bbdad57)
Posted: Sun Oct 04, 2009 2:37 pm
by star_deceiver
The rad petcock is on the drivers side of the rad accessing it from in the engine bay, you'll need some rubber hose. I can't recall on the engine itself, it's been a year or two since I saw the lower portion of a 1zz.
Posted: Sun Oct 18, 2009 1:44 pm
by jamesmetairie
i brought up that topic once before. one of the guys said if you want to try to bleed the system maybe you could loosen or disconnect one of the hoses. otherwise there ain,t no bleeder valve.
