Opening up a tail light, tips? (update 10/2/09 Opened!)
Posted: Wed Sep 30, 2009 12:57 pm
by Whelan
I got my Ebay OEM taillight and it's in great shape and perfect for my LED project as the dummy lens.When I did the headlights on my Civic I used my heat gun. It took a little while and some prying with a screwdriver. Then after I went back and scraped all the excess out of the channel and did a great re-seal with clear silicone and clamps for a full 24 hours.I have heard people bake them and am not sure if that is so safe or a good idea. Anyone else? I may stick with my heat gun for my taillights.
Re: Opening up a tail light, tips? (Whelan)
Posted: Wed Sep 30, 2009 7:38 pm
by keithvibe
If they are OEM tails. You won't be able to bake them open. They are flash sealed. *plastic to plastic* Only way to open them is to dremel them with a cut off wheel. If they are the aftermarket tails that you can buy on ebay, yes you can bake them open.
Posted: Wed Sep 30, 2009 9:10 pm
by Wolfman213
That is not a good thing to hear Guess I should have bought that plastic welder that was on the woot-off the other day lol.
Re: (Wolfman213)
Posted: Wed Sep 30, 2009 10:18 pm
by Whelan
Are you sure they are flash sealed? My 02 Civic headlights were glued with some kind of gray sealant.
Re: (Whelan)
Posted: Wed Sep 30, 2009 11:00 pm
by lovemyraffe
The easiest way would be to let some punk-@$$ kid roll a utility truck in to the back of your car. It makes it hard to put them back together though.
http://forums.genvibe.com/zerothread?id=38821
Re: (Whelan)
Posted: Wed Sep 30, 2009 11:15 pm
by keithvibe
The headlights are different then the tail lights. You were talking about headlights on your civic and your talking about tail lights on your Matrix. trust me on this one.
Re: (keithvibe)
Posted: Thu Oct 01, 2009 1:52 am
by Whelan
Ugh. Well They are comin apart somehow in the next day or two.
Re: (Whelan)
Posted: Thu Oct 01, 2009 1:57 am
by ou.grizzly
Laser beam!
Posted: Thu Oct 01, 2009 4:19 am
by keithvibe
AdamSend PMAG a PM on MO and ask him. I know he has opened up a set in the past, though I think it didn't turn out well
Re: Opening up a tail light, tips? (keithvibe)
Posted: Thu Oct 01, 2009 5:27 am
by Whelan
I may do that, he is on TMG too now.
Posted: Thu Oct 01, 2009 5:29 am
by Wolfman213
I know that we've been speaking Matrix this whole time; am I to assume that it's the same for the Vibe as well AFA being a plastic weld?
Posted: Thu Oct 01, 2009 5:31 am
by ou.grizzly
PMAG = Pour Me a Guinness MO = Matrix OwnersPM = Personal MessageTMG = The Matrix Garage
Re: (ou.grizzly)
Posted: Thu Oct 01, 2009 6:13 am
by keithvibe
Quote, originally posted by ou.grizzly »PMAG = Pour Me a Guinness MO = Matrix OwnersPM = Personal MessageTMG = The Matrix Garageding ding ding.. grizz wins the booieprize
Re: (keithvibe)
Posted: Thu Oct 01, 2009 6:14 am
by ou.grizzly
Quote, originally posted by keithvibe »ding ding ding.. grizz wins the booBieprize Fixed it for ya.
Re: (ou.grizzly)
Posted: Thu Oct 01, 2009 2:35 pm
by Whelan
Done!Took some finesse and about 10 minutes. I used a small Swiss Army Knife and used the metal file blade shown below. Then I gently got the blade pried in between the plastic case and backing. I started on the top corner above the 3 reflectors and worked my way around. You have to be careful though cause you could crack the clear plastic easily. I went from the corner across the top. Then from the top corner where I started down along the bottom to the reverse lamp. At this point it is pretty hard to get in deep enough to split the plastics on the inside edge, but there was enough pried apart that the lens basically pulled apart easily. Now I was curious about the red lens. It's held into place by two small pop clips that are part of the lens. With the knife blade of the SAK I gently went in (careful not to harm the fake chrome) and popped off the outside clip, the lens fell out after that. The back of the reflector on the Matrix lens has an external reflector that can be removed, then the backing is a fake chrome which refracts light back onto the concave interior.
Re: (Whelan)
Posted: Thu Oct 01, 2009 7:36 pm
by keithvibe
GREAT
Posted: Thu Oct 01, 2009 8:43 pm
by Wolfman213
Hopefully I'll be able to snags Raffe's broken lens and see if I'll be able to finagle them the same way!
Posted: Fri May 14, 2010 2:00 am
by A Psycho Martyr
I had an idea that maybe instead of yellow turn signals My brake lights could act as turn signals as well. I see it ALL the time on other cars. The same bulb for both. How could I get this to work with mine?
Re: Opening up a tail light, tips? (A Psycho Martyr)
Posted: Fri May 14, 2010 4:20 pm
by vibedrivermatt
So how do you plan to rejoin the parts together. Are you using a kind of adhesive? uhhh silicone?
Re: Opening up a tail light, tips? (vibedrivermatt)
Posted: Sun May 23, 2010 5:30 pm
by chloeelvis
cool. very great post.
New Idea??
Posted: Thu Oct 28, 2010 4:03 am
by Ls1jorge
Was this project ever finished, I took my car to a guy on craiglist he runs his own shop, he sells LEDs, hids, neon underglow lights, speaker systems..etc & I asked him if he could put leds in my stock tailight housing for braking & turn signals, he told me it can be done with modifcation with the wiring & install, he hasn't gave me a price yet but should I give it a shot???
Posted: Sun Apr 10, 2011 12:05 pm
by A Psycho Martyr
if someone doesn't do a friggin how-to already I'll do it myself!
Posted: Mon Apr 11, 2011 7:50 am
by 06pvibe
Quote, originally posted by A Psycho Martyr »if someone doesn't do a friggin how-to already I'll do it myself! I am forced to agree. This has gone on for a while now and if someone is going to do this mod, then please do it and post it up.
