2005 timing belt?
Posted: Tue Sep 15, 2009 10:28 pm
by krisP
Anybody know where I would find the recommended timing belt change info for a 2005 Vibe?Thanks in advanceKP
Re: 2005 timing belt? (krisP)
Posted: Wed Sep 16, 2009 6:25 am
by keithvibe
There isn't a timing belt on the car, but a timing chain and you are good for 300,000+ miles.
by Cougar Vibe
Darn it...I was just going to make him happy and say the same thing.
Re: (Cougar Vibe)
Posted: Wed Sep 16, 2009 7:07 am
by keithvibe
Quote, originally posted by Cougar Vibe »Darn it...I was just going to make her happy and say the same thing.should read ^^^ because **kristin** to me is a female.
Posted: Wed Sep 16, 2009 7:30 am
by ou.grizzly
Timing Chains can stretch/wear out over time. I am not sure if I would let mine go until 300,000 miles.
Re: (ou.grizzly)
Posted: Wed Sep 16, 2009 10:58 am
by djb383
A little stretch/wear in a chain is no big deal...........when a rubber belt breaks, in an interference type engine, that's disastrous. Doubt the chain will ever break.
Re: (djb383)
Posted: Wed Sep 16, 2009 11:01 am
by ou.grizzly
Quote, originally posted by djb383 »A little stretch/wear in a chain is no big deal...........when a rubber belt breaks, in an interference type engine, that's disastrous. Doubt the chain will ever break. Rear up on timing chains stretching on Honda Engines and causing the teeth to "skip." Yes, the likely hood of timing chains breaking is rare, but they do stretch. I for one would not let a timing chain go for 300,000 miles. I would change it would at 150,000 as preventative maintenance; same goes for the water pump.
