need pictures of fog light area and trim cover 09+
Posted: Sat Sep 12, 2009 3:45 am
by SpeedEng
I gathers some parts (fogs off a toyota) and I just need a few pictures of the AWD fog lights and the trim...I saw the GT today and it looks way different from my base 09..
Posted: Mon Sep 14, 2009 8:25 am
by Kincaid
http://forums.genvibe.com/zerothread?id=37731Is this enough of a close up? (I am assuming Houston doesn't mind me linking his photo thread here).
Re: (Kincaid)
Posted: Mon Sep 14, 2009 9:40 pm
by SpeedEng
I need it closer im pretty close to using a hole saw and cutting the covers..im wondering if it's cut at a slight angle?
Posted: Mon Sep 14, 2009 11:50 pm
by Kincaid
I would say that because the covers are angled at almost 45 degrees, you'd have to come in at that angle, otherwise you'll have an ellipitical hole (kind of like a cat's eye - or maybe the eye of Sauron, lol) that you are shining a round light thru.Unless you can set up a jig, I'd suspect it might be easiest to cut them on the vehicle. If you mess up - you can buy my old covers and try again!Does the hole saw have a center bit to keep you lined up? If so, go real slow and steady.
Re: (Kincaid)
Posted: Tue Sep 15, 2009 11:27 am
by SpeedEng
yea it has a center drillbit.. but another problem i ran into..the fogs are 4" in dia I have a 4 inch and a 5'' hole saw bit guess im going with a 4" and some dremel action
