screw in tire...possible to patch/plug? - photos included
Posted: Sat Sep 12, 2009 1:53 am
by justoffthecoast
I've been losing about 10psi/week on my rear passenger tire, so I took it in to NTB this morning to get a patch. They told me they couldn't patch it because it's too close to the sidewall. I'm no tire expert, but it looks to me like there's a solid inch or more between the screw and the sidewall. These are also the same guys that mounted a directional tire backwards for me, so I tend to be skeptical of anything they say.
http://freshzive.com/misc/tire.JPGhttp: ... ire3.JPGIs this feasible to patch? What are the odds that another mechanic would do it for me? Has anyone had success with do-it-yourself kits, and if so, what do you recommend?
Re: screw in tire...possible to patch/plug? - photos included (justoffthecoast)
Posted: Sat Sep 12, 2009 2:49 am
by star_deceiver
That should be a simple 10 minute job for any tire shop. Take it somewhere else, especially if they can't figure out which way the direction arrow goes...
Posted: Sat Sep 12, 2009 3:14 am
by Whitegts
I have been plugging my tires for years now. I have never had a failure doing this. I just buy the one kit you can get at any auto parts store or even wal-mart. There is plenty of how to's on the net. And yes that should have been plugged by them, it doesn't look to close. Thats kinda why I started doing it myself since they would always try to sell me a new tire instead of fixing it.
Posted: Sat Sep 12, 2009 5:04 am
by lovemyraffe
Quote, originally posted by star_deceiver »Take it somewhere else, especially if they can't figure out which way the direction arrow goes...Take it somewhere else. I wouldn't go back to a shop that can't install a directional tire the right way.
Posted: Sat Sep 12, 2009 5:55 am
by zionzr2
Tires 1 and 3 are not fixable too close to the shoulder or edge of tire.Tire 2 is close and should be fixable with a plug.there is a picture I have seen at shops and cant seem to find on the internet that shows the safe areas that can be patched on a tire.
Re: (zionzr2)
Posted: Sat Sep 12, 2009 6:32 am
by justoffthecoast
Quote, originally posted by zionzr2 »Tires 1 and 3 are not fixable too close to the shoulder or edge of tire.Tire 2 is close and should be fixable with a plug.there is a picture I have seen at shops and cant seem to find on the internet that shows the safe areas that can be patched on a tire.They're all pictures of the same tire.
Posted: Sat Sep 12, 2009 8:16 am
by djkeev
I'd fix it if it were mine. Got the materials in my garage, swing on by!My money's on that they want to sell you a new tire.I HATE incompetence in auto repair / service!!!Dave
Posted: Sat Sep 12, 2009 8:24 am
by ou.grizzly
And another site states different...
Posted: Sat Sep 12, 2009 11:46 am
I'd plug it, unless the screw is long and angled out towards the sidewall. I carry a plug kit and compressor in the car, have only needed it twice in the Vibe, really handy when you need it.Shops around here won't plug tires, they unmount them and patch the inside. I have had good luck with plugs though.
Re: (zionzr2)
Posted: Sat Sep 12, 2009 4:03 pm
by jake75
Quote, originally posted by zionzr2 »Tires 1 and 3 are not fixable too close to the shoulder or edge of tire.Tire 2 is close and should be fixable with a plug.there is a picture I have seen at shops and cant seem to find on the internet that shows the safe areas that can be patched on a tire.All pic of same - priceless!
Re: screw in tire...possible to patch/plug? - photos included (star_deceiver)
Posted: Sat Sep 12, 2009 4:28 pm
by TONY TAT2
I would have my S-I -L do a inside patch. I just use the plug type untill I can get the tire over to him. Way back I had some1 ice pick the sidewalls on my new 79 El Camino,I had the sidewalls patched from the inside & had them install Radial Tubes,no problemes with the tubes at all,ran them till it needed new tires.
Posted: Sun Sep 13, 2009 1:54 am
by beemerphile1
You're pretty much at the outer edge of repairable area but it is fine. I carry a plug kit with me and usually plug em without even taking it off the car. Buy a kit at the auto parts store for $5 and do it yourself, then carry the kit with you.
Posted: Sun Sep 13, 2009 5:38 am
by ou.grizzly
Even a person can do a patch-plug themselves at home and have the shop re-mount the tire later on at a different location.day.
Posted: Mon Sep 14, 2009 12:28 am
by Sublimewind
I'd plug that in a heartbeat... FYI, the plug kits with the T handle tools are SOOOOOOOOOO much easier to use than the straight handle screwdriver type tools... Make sure the kit comes with rubber cement, it both lubes the plug, so it's easier to insert and it also glues it in place, once it's dried... FWIW, I've NEVER once had an issue with a plug job I've performed... I've done them on my Subaru, in which I used to rally around on the dirt roads out here all the time, on plugs.. I've not been easy to some of my tires... lol..
Re: (Sublimewind)
Posted: Mon Sep 28, 2009 12:16 pm
by cq358
I've work in the dealership for 5 years .. I plug few hundreds tires in this toyota dealership. Base on my experience, all 3 tires can be plug. Spend 10 bucks and buy a T handle plug kit should be good enough.Just remember to pump the tire to 45 psi before you plug it.. so it will make your life easier. ( it easier to plug a fully inflated tire .. but never exceed the side wall maximum pressure)Try cut off a coroner off (Bevel)from the rubber strip so you can insert into the hole on the T handle more easily.put lot of glue (came with the kit) on the rubber stripPull the nail out use the (removed) screw tool and try enlarge the hole a little bit..by pushing in and out two times..Fully plush the T handle into the hole all the way inmake a half turn (180) on the handle and pull the T handle thing out as fast as possible.Cut off the excess rubber strippour soap water on the repaired are and confirm nothing leakif still leaking air then use a side cutter and pull the rubber strip out again and re do the procedure
Re: (cq358)
Posted: Tue Sep 29, 2009 1:37 am
by Sublimewind
Quote, originally posted by cq358 »Fully plush the T handle into the hole all the way inmake a half turn (180) on the handle and pull the T handle thing out as fast as possible.Cut off the excess rubber strippour soap water on the repaired are and confirm nothing leakif still leaking air then use a side cutter and pull the rubber strip out again and re do the procedureI agree with everything up to this point Sir... i've had plugs fall off inside of the tire on my when I pushed the plug ALL the way through.... I like to push the plug in 3/4 of the way (slowly, it can be difficult), turn it 1/4-1/2 turn and yank it back out... That way I KNOW, the plug is in place and in place GOOD.. Otherwise, yep...
Re: (Sublimewind)
Posted: Tue Sep 29, 2009 11:34 am
by cq358
Thanks Sublime,3/4 way in also good too.. it really depends the quality of the rubber strip.. I wish I can buy those grey and smooth rubber strip that made in japan.. somehow my shop foreman manage to get it from a tire supply store.but since i don't work in the dealership anymore and have to rely on those black sponge like cheap rubber patch strip which sometime do get stuck and never come out even you pull it slowly. It is just way too thick for needle eye on the t shape tool to slice it properly..enough complain but we still manage save at least 80 bucks from patching it in the tire shop.It is on God's script that we need to run over the nail some day. we are just following God's plan and have to learn how to deal with it..
Posted: Tue Sep 29, 2009 11:38 am
by ou.grizzly
Forgot to mention this, but worst case is have a shop dismount the tire from the rim, take the tire home, plug-patch it yourself, and then take the tire back to another shop, have it mounted and re-balanced + installed...
Posted: Wed Sep 30, 2009 10:36 am
by star_deceiver
And even if the manager refuses to do business with you, have a chat with the guys actually doing the work. Cash under the table and/or beer can get a lot of work done!!!
