Periodic Clutch Maintenance?
Posted: Thu Sep 10, 2009 9:28 am
by tots
Hi -Is there any maintenance that needs to be performed on a clutch? I have 78K miles on my 04 Vibe and am not having any problems, but was wondering if there is any required maintenance. Should a clutch be replaced after some number of miles - say after 120K miles?Thanks.
Re: Periodic Clutch Maintenance? (tots)
Posted: Thu Sep 10, 2009 11:32 pm
by Herb
I would say if it isn't slipping you shouldn't need to change. You might want to change the oil at whatever the service interval is which should be in the owners manual
Posted: Fri Sep 11, 2009 12:21 am
There really sin't any maintenance on the clutch itself, other than to replace it and resurface the flywheel when the clutch is worn out. And +1 to Herb's recommendation to change the tranny oil. The 03's had a higher than normal bearing failure rate. I don't think it affected the 04's, but it wouldn't hurt.
