CEL on. Thru po133, po134, po171 and p2195
Posted: Thu Sep 03, 2009 4:44 am
by woodyg
Just purchased 2006 vibe, thru codes of po133, po134, po171, p2195,what i have done so far1) cleaned MAS with MAS cleaner ( I disconnected battery so the ecm got rebooted2) I added large bottle of techron to high octane gas( have driven about 100 miles so farCEL came back onwhat I plan on doing1) change PCV valve2) wondering of i need to change intake manifold gasket ( does anyone know if the 2006 had an issue with the gasket)3) planning on ordering an SNG oxygen sensor ( $78 online) for the bank 1 sensor 1( the one right behind the engine in the exhaust manifold)Please give me your input
Re: CEL on. Thru po133, po134, po171 and p2195 (woodyg)
Posted: Thu Sep 03, 2009 10:34 am
by Raven
Most likely your O2 sensor or possibly a vacuum leak.There's a TSB for the 2006 Toyota Matrix 1ZZFE, same as the Vibe. Here it is:Component Description:12. ENGINE AND ENGINE COOLING Bulletin Number: 05105 Bulletin Date: Nov 2005 Vehicle: 2,006 Toyota Matrix Summary:MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0171 OR P2195. ( NHTSA ITEM NUMBER - 10018290 )
Re: CEL on. Thru po133, po134, po171 and p2195 (Raven)
Posted: Mon Sep 07, 2009 12:22 am
by woodyg
Raven thanks for the reply I have not investigated the tsb yet but will. I clean the mafs and i changed the pcv valve. I also changed the spark plugs and they were toast. the cel came back on and i ran the codes the only code was the po134( a dead o2 sensor at bank 1 sensor 1) I am going to order a sng sensor and i think that will take care of the issue ill keep you posted
Posted: Mon Sep 07, 2009 12:29 am
by jake75
Are O2 sensors covered by the longer emissions warranties?
Posted: Mon Sep 07, 2009 9:43 am
by Tonebalone
Those should be covered by the 80K mi. emission warranty.
Re: (Tonebalone)
Posted: Mon Nov 16, 2009 9:55 am
by woodyg
I ordered the part last week and just recieved my SNG o2 sensor $78 I installed it in 15 minutes. I cleared the codes and have driven around a little so far so good I will post again if anything changes
