2010 Vibe - 1.8L / 4Speed Auto - Acceleration
Posted: Thu Aug 27, 2009 9:18 am
by iucu
How hard you press the pedal, what is your driving style with your 1.8l and 4 speed auto, where the engine RPM goes when you shift form first to second and thirth ? I am refering let say at Stop (example) where not too many people are able to wait behind you while you, for shifting, gentle press the pedal (say no more then 2000 RPM) ... Do you go ofen over 2500 or 3000 RPM to shift ?
Posted: Thu Aug 27, 2009 9:36 am
by ou.grizzly
The new 1.8L is a lot faster than the 1st gen 1.8L Vibe engine.
Posted: Fri Aug 28, 2009 9:45 am
by ou.grizzly
IUCU,If you want to compare a 2008 to a 2009, I will be more than happy yo let you drive my vehicle so you can compare. To reach pull HP and Torque, higher RPM's are needed.
Re: (ou.grizzly)
Posted: Fri Aug 28, 2009 10:47 am
by iucu
I am in process of acomodating myself with higher RPM engines and automatic transmission ! If the car is not mine !!! maybe I can press the pedal to 3000 RPM to shift faster but with mine I am trying to stay at 2000 however I am loosing that passion and I am starting to go higher.. For what I see this engine run anyway between 2000 and 3000 RPM. Hopefully it is a reliable engine, if Corolla has the reputation of 200,000 mile why this one should not ?
Re: 2010 Vibe - 1.8L / 4Speed Auto - Acceleration (iucu)
Posted: Fri Aug 28, 2009 10:48 am
by jake75
They either have to wait behind me, go around me or hit me in the (removed). I neither tarry excessively nor waste gas by jack rabbit starts from a stop. And I let the transmission do the shifting. That's what I bought an AT for.I have never paid attention to the rpms at the shift points.
Re: (iucu)
Posted: Fri Aug 28, 2009 10:54 am
by ou.grizzly
Quote, originally posted by iucu »I am in process of acomodating myself with higher RPM engines and automatic transmission ! If the car is not mine !!! maybe I can press the pedal to 3000 RPM to shift faster but with mine I am trying to stay at 2000 however I am loosing that passion and I am starting to go higher.. For what I see this engine run anyway between 2000 and 3000 RPM. Hopefully it is a reliable engine, if Corolla has the reputation of 200,000 mile why this one should not ?Let me know when your free and I will see it if fits into my schedule. I am more than willing to let you see the similarities and differences. You must of had an older Explorer to have a 5 speed manual transmission. What year was it, a 1994?
Re: 2010 Vibe - 1.8L / 4Speed Auto - Acceleration (jake75)
Posted: Fri Aug 28, 2009 10:59 am
by keithvibe
it's been proven that getting up to speed quicker then coasting uses less gas then slow drawn out starts. Your using more throttle for those long gradual up to speed runs than one quick burst and then coast and crack the throttle to keep speed.Try it for a tank of gas and you will see you get better gas mileage. for me: if the speed limit on the road is 45. Starting from a stop I get up to 4500-5000rpm in my first gear and then about 3000 in second... by then I am up to speed then I feather back and just coast and crack the throttle.
Re: 2010 Vibe - 1.8L / 4Speed Auto - Acceleration (keithvibe)
Posted: Fri Aug 28, 2009 11:04 am
by ou.grizzly
Quote, originally posted by keithvibe »it's been proven that getting up to speed quicker then coasting uses less gas then slow drawn out starts. Your using more throttle for those long gradual up to speed runs than one quick burst and then coast and crack the throttle to keep speed.Try it for a tank of gas and you will see you get better gas mileage. for me: if the speed limit on the road is 45. Starting from a stop I get up to 4500-5000rpm in my first gear and then about 3000 in second... by then I am up to speed then I feather back and just coast and crack the throttle.AWD right? Def not the fastest starting off compared to other Vibes. Really need to get the RPM's up there I am sure.
Posted: Fri Aug 28, 2009 11:28 am
by TONY TAT2
Got ya both beat,I had a 93 Pontiac /Le mans/mexican built/ dawoo with the 1.8 & the trans felt like a 2 speed power glide /LOL !!!I COULD WALK FASTER !
Re: 2010 Vibe - 1.8L / 4Speed Auto - Acceleration (TONY TAT2)
Posted: Sat Aug 29, 2009 9:23 am
by panchess
Gen II is definitely quicker off the line with the base engine, as well as being quieter.
Posted: Sun Aug 30, 2009 10:05 am
by file014
I usually take off slower in my vibe than my other cars, but thats because I want it to last forever. Im not concerned about durability, but im just taking it easy. I got 34 mpg last fill up with about 50 miles in town and 140 highway!
Re: (file014)
Posted: Mon Aug 31, 2009 9:18 am
by iucu
I am shifting from 1 to 2 and then to 3 at ~ 2000-2500 RPM
