Tenzo R DC-5
Posted: Fri Aug 21, 2009 11:34 am
by Vibe2009
Find this used Rim for sell with the following spec:Size: 17" x 7"Bolt Pattern (mm): 5/114.3 & 5/100Offset (mm): 42Weight (lbs): 17.5Will this work with my 2009 vibe currently fitted with 17in chrome clad rim?
Posted: Fri Aug 21, 2009 10:28 pm
by Sublimewind
They should, the offset might be a little off, I think our cars are +35 so the +43 will just set them into the hweel wells a little more... Don't quote me, but they should work..
Re: (Sublimewind)
Posted: Mon Sep 14, 2009 12:36 am
by vibolista
Hey Sub, I don't think I have seen a post for the 09/10 Vibe OEM wheel selection offsets yet. The original single bolt pattern (5X100) Vibe used a 39mm offset on the 16 inch steel and 16 inch alloy and a whopping 45mm offset for the option 17 inch alloy. After a lot of head scratching and measuring, I opted for an aftermarket alloy wheel with a 38mm offset, and it looks like I could have installed a 35mm offset to bring the tire/wheel to a pefectly flush fitment with the plastic wheel well trim on my 08 Vibe. Maybe some 2nd gen Vibe owner could find that out and post it for future reference???
