Metal grinding or whistling noise from driver's side front wheel
Posted: Sun Aug 16, 2009 12:39 am
by ilyakoz56
I have a metal grinding/whistling noise comming from my driver's side front wheel. The noise comes as soon as as I start driving and continues for about 10 minutes, then goes away. It also goes away when I turn the wheel any direction when driving but comes back when going straight. For some reason it does this only for the first 10 minutes of driving. Can anyone help diagnose this problem. The breaks work well and when applied it silences the noise as well. I have no idea but I don't want to take it in just yet. Thanks in advance.
Re: Metal grinding or whistling noise from driver's side front wheel (ilyakoz56)
Posted: Sun Aug 16, 2009 1:28 am
by BlueCrush
That is the same issue I am having with mine as well: http://forums.genvibe.com/zerothread?id=38010Sounds like this might be our problem... http://forums.genvibe.com/zerothread?id=37982I saw you have a 2005 from your other thread. Is it a Base, AWD or GT?
Posted: Thu Aug 27, 2009 1:10 pm
by ilyakoz56
Mine is a base
Posted: Thu Aug 27, 2009 1:18 pm
by ilyakoz56
Thanks for the thread I am going to try to get the tires balanced, may be that will help.
Posted: Fri Aug 28, 2009 12:18 am
by Sublimewind
Quote, originally posted by ilyakoz56 »I have a metal grinding/whistling noise comming from my driver's side front wheel. The noise comes as soon as as I start driving and continues for about 10 minutes, then goes away. It also goes away when I turn the wheel any direction when driving but comes back when going straight. For some reason it does this only for the first 10 minutes of driving. Can anyone help diagnose this problem. The breaks work well and when applied it silences the noise as well. I have no idea but I don't want to take it in just yet. Thanks in advance.Usually when you have noise issues that come and go with turning of the steering wheel, it points toward the wheel bearing... something to consider.. Usually, turning the wheel makes the noise change when it's a hweel bearing. though.. not go away.. ?
Re: Metal grinding or whistling noise from driver's side front wheel (Sublimewind)
Posted: Fri Aug 28, 2009 12:28 am
by BlueCrush
Quote, originally posted by Sublimewind »Usually when you have noise issues that come and go with turning of the steering wheel, it points toward the wheel bearing... something to consider.. Usually, turning the wheel makes the noise change when it's a hweel bearing. though.. not go away.. ? That is exactly what mine does. It comes and goes. Some days it is gone, other days it is quite annoyingly loud. I'm thinking the change (coming and going) probably has to do with the humidity levels. So would replacing the wheel hub pretty much take care of it?
