08 xb headers on 09 vibe gt?
Posted: Sun Aug 09, 2009 6:58 am
by skillz305
i know theyll fit but will the cel come on ?
Re: 08 xb headers on 09 vibe gt? (skillz305)
Posted: Mon Aug 10, 2009 6:47 am
by satur9
im not sure they will fit. but if you are .then no, you shouldnt get a cel as long as the o2 sensor(s) is in place . and there are no exhaust leaks.
Posted: Mon Aug 10, 2009 4:48 pm
by skillz305
thanks buying them next week will let everyone know how it comes out
Re: (skillz305)
Posted: Tue Aug 11, 2009 7:58 am
by Jyik40
You will get a CEL if you put a catless header on your car. You'll end up getting the P0420 code (due to a lack of a pre-cat). There is a secondary o2 sensor located after the pre-cat that determines the pre-cat's efficiency levels by measuring the amount of unburnt fuel left in the exhaust stream.
Posted: Thu Aug 13, 2009 4:20 pm
by skillz305
ok ended up putting tc headers and they fit perfect cel came on about 50 miles later but buying the cel fix
Re: (skillz305)
Posted: Fri Aug 14, 2009 6:05 am
by satur9
for some reason i was under the impression you were putting on stock scion headers. i will now assume since you got a cel. that they were infact aftermarket. do they delete a cat or something.do a search for cel fix exhaust . you can try a spark plug defouler 18mm mod it. put it on. it might fix your cel. if not your only out of 1.50$ and no electronics or wiring involved.
http://www.spyderchat.com/foru...ensorheres a link to the mod.
Posted: Wed Aug 19, 2009 7:56 am
by skillz305
cel fix didnt work returning it ,,,,anti fouler trick insteadnon drilled p42009 ---- non drilled p42002 ----- drilled p42002 no cel yet only 20 miles since i put them on
Re: (skillz305)
Posted: Wed Aug 19, 2009 9:02 am
by vibenvy
Quote, originally posted by skillz305 »ok ended up putting tc headersYou're getting a check engine light because you're trying to put more than one header on a car that only has one .
Posted: Thu Aug 20, 2009 1:57 am
by skillz305
200 miles no CEL only p0137 came on cause i didnt reset the ecm after putting them in but its all good now
Re: (skillz305)
Posted: Mon Sep 14, 2009 3:41 am
by Myevo8u
do you have a pic of the header on your car you can email me so I can see what it looks like. also how much trouble was it to install?
Posted: Tue Sep 15, 2009 5:10 am
by Kincaid
Don't email a pic! Post it here!
