2009 2.4L Trans Cooler Install
Posted: Sat Aug 08, 2009 7:43 am
by markd78
Disconect the OEM cooler or thru the OEM cooler then Hayden cooler ?? And which line is in to OEM cooler ??.Mark
Re: 2009 2.4L Trans Cooler Install (markd78)
Posted: Sun Aug 09, 2009 10:07 am
I don't know which is in and out on the stock cooler, but I'd recommend adding the extra cooler to the stock cooler, not bypassing it. They are for the earlier generation vibes, but two threads about tranny coolers are
http://forums.genvibe.com/zerothread?id=23452 and
http://forums.genvibe.com/zerothread?id=20931maybe yours is similar
Re: 2009 2.4L Trans Cooler Install (joatmon)
Posted: Sun Aug 09, 2009 11:47 am
by djb383
What joat said, don't bypass the OEM cooler. For max fluid cooling, the OEM cooler cools the fluid 1st, then the fluid should flow to the auxiliary/second cooler for further/max cooling, then it flows back to the tranny.
