Removing Roof rack cross rails.
Posted: Thu Aug 06, 2009 2:16 am
by MSAGRO
I know you pop the black end cap, but on the front or rear.It seems like on the rear, the antenna base would block removal.Advice and instruction please.Msagro.
Re: Removing Roof rack cross rails. (MSAGRO)
Posted: Thu Aug 06, 2009 2:22 am
by Kamikaze
unscrew the antenna, pull the 2 roof caps from the rear and slide the cross rails towards the back, you just have to use a little elbow grease to get the rails past the antenna base.
Posted: Thu Aug 06, 2009 2:26 am
by MSAGRO
Thanks for the fast answer Kamikaze,One more question.I take a small screwdriver, stick it down between the rubber base gasket and lift up?Where should I position the screwdriver at the base? Left, right, center of the cap as I face the side of the car?
Posted: Thu Aug 06, 2009 2:29 am
by bull77
theres a couple links in there about removing the bars -#24http://forums.genvibe.com/zerothread?id=25918
Posted: Thu Aug 06, 2009 2:31 am
by MSAGRO
Thanks, thats what I was looking for.
Re: (MSAGRO)
Posted: Thu Aug 06, 2009 11:42 am
by MSAGRO
Pfft! 6 and a half minute job! Easier than when I 'derailed my Highlander.Thanks for the info... I'm gonna enjoy it here.
Re: (MSAGRO)
Posted: Thu Aug 06, 2009 8:49 pm
by bull77
time to start a For Sale thread for those rails -- always seems to be someone looking for a set
Posted: Sun Aug 09, 2009 2:51 am
by MSAGRO
Maybe I should. OK, 2 Vibe rails for sale.PayPal me.Vibe looks so much smoother without the cross rails.
Re: (MSAGRO)
Posted: Sun Aug 09, 2009 2:56 am
by scherry2
now you need to powdercoat those rails either black or the body color.
Posted: Sun Aug 09, 2009 6:25 am
by MSAGRO
Yeah, powdercoat black.
Re: (MSAGRO)
Posted: Fri Apr 30, 2010 11:22 am
by evinmathai
I'm definitely a n00b and can't figure this out. lol
Posted: Sat May 01, 2010 3:19 am
by cptnsolo77
Looks good! Sure cleans up the look. Easier to wash the car too im sure.
Posted: Sat May 01, 2010 3:38 am
by waveresponder
if you have a factory xm antenna you cant install/remove original rails. or at least i wasnt able to without snapping the xm antenna. just super glued it back, signal was clear after i glued it. dont use xm anymore anyways, and just canceled my sirius subscription after it was up cuz its too expensive IMO (20some bucks more then i paid last time)but yah just pry up the rear black plastic covers slowly with a screwdriver being careful not to scracth or break anything
Posted: Sat May 01, 2010 10:35 pm
by A Psycho Martyr
I kinda like mine since the're black
