WRX 16" wheels on a 2003 Vibe?
Posted: Mon Aug 03, 2009 4:49 am
by 98se5speed
Has anyone ever tried or seen a set of 16" Subaru WRX wheels on a Vibe? I found a cheap local set, but am concerned about the high offset of the wheels (55mm WRX vs. 38mm? Vibe). I asked the seller if I can maybe test-fit 1 or 2 of them on my car before buying them, guess I'll see what he says. Just figured I'd ask here if anyone had ever heard of a Vibe owner putting them on. I did a quick photo-chop, the design seems to fit the car well.
Posted: Mon Aug 03, 2009 7:33 am
by Sublimewind
I was going to put 17" subaru alloys on my Vibe and sold them before I could, TO a Viber, which i've never seen, nore herd from here since? They should fit, but I would try one to be certain.If they clear the brakes and whatnot, they WILL need different lug nuts than what comes with the Vibe.. I can tell you that for sure.. beware, the stock Vibe lugs will likely ruin the WRX wheels..
Re: WRX 16" wheels on a 2003 Vibe? (98se5speed)
Posted: Mon Aug 03, 2009 11:24 am
by vibolista
If the Subie wheels fit, they will still sit a full 16 millimeters farther inside your wheel well than a normal Vibe steel wheel with a 39mm offset. Your vibe may end up looking a little like this?? It was a great look way back in 1956!!!
Posted: Tue Aug 04, 2009 1:01 am
by 98se5speed
Good call on the lugs, I'd get some new ones anyways since the stock lugs for hub caps are those ugly-azz ones with the threads for the hubcap nuts. I might have some regular ones laying around to use for the trial, 12x1.50 for Toyota, right? Dang, I had a whole set of Toyota tuner lugs, left them on my 96 Corolla when I sold it though. Having the wheels fitting inward towards the center of the car isn't exactly a look I'm going for, but I figured I'd first see if that 16mm was really noticeable first. Whole set for $150, hard to go wrong.
Re: (98se5speed)
Posted: Tue Aug 04, 2009 11:21 am
by vibolista
That is a really good price. Tires come with those? Check Tirerack and Discounttiresdirect. Alloys with 35 to 40mm offsets are available for under a hundred bucks a piece. Someone else posted a picture of a Vibe with similar Subie wheels. I even think it was silver with dark cladding just like ours. Might be able to search that one out on genvibe. The picture did show that 16mm difference fairly well.Hope they work out!
Re: (vibolista)
Posted: Tue Aug 04, 2009 11:10 pm
by 98se5speed
Well, the person selling on craigslist never replied to me, so maybe they sold already. Ad is still up though. They did come with tires, but 205/50's, so a tad shorter than needed. I didn't really care about the tires, since the ones I have on the steel wheels are like new. Well, it was worth a try, just to get some alloys for so cheap. Surely lots of options out there in the ~$100 per wheel range. I actually found a cheap set of 5-spoke 16" wheels on tirerack.com that looked pretty nice, about $380 delivered for a set of 4. Not bad. $150 sounds a lot nicer though! I really shouldn't complain TOO much, the wife just got hit by some teenager and we made about $2900 off the incident. Tire rack wheels:
Posted: Wed Aug 05, 2009 7:59 am
by cptnsolo77
Those are the EXACT wheels I have been looking at on Tirerack. They are the Sport Edition F7s. They look similar to the TRD wheels I have seen on here before. When you buy them please post pics!!!
