Fan Switch 2006 Vibe
Posted: Tue Jul 21, 2009 3:50 am
by NancyBrnsn
Fan switch, resistor, whatever. Should be repaired at no charge to owners.
Re: Fan Switch 2006 Vibe (NancyBrnsn)
Posted: Tue Jul 21, 2009 3:59 am
by BlueCrush
Are you having problem with the fan not working or only working on high? If so, is the blower motor resistor that is in need of replacement not the switch. Tell us what is happening so we an help you out.Welcome to GenVibe, btw.
Re: Fan Switch 2006 Vibe (BlueCrush)
Posted: Tue Jul 21, 2009 4:01 am
by NancyBrnsn
Hey - thanks for the welcome. I love my Vibe, but this motor resistor has been out since last fall. (About the same time as I had to switch from A/C to heat.) So, what do I have to do about getting it fixed?
Posted: Tue Jul 21, 2009 4:09 am
by BlueCrush
The part# is in here: http://forums.genvibe.com/zerothread?id=23496And the How-to is in here (on the second half of the thread): http://forums.genvibe.com/zerothread?id=36099Hope this helps!
Posted: Tue Jul 21, 2009 4:53 am
by NancyBrnsn
Thanks Crush. I will get the part and fix it myself. It should be easy. I won't even get greasy.
Posted: Tue Jul 21, 2009 5:00 am
by BlueCrush
No problem. It should be an easy fix. Let us know how it goes and if you have any more questions.
