				Front disc brakes "clunk"
				Posted: Thu Jul 16, 2009 8:49 am
				by richard_v
				I have 4 Vibes in the family. Mine is a 2008. I am experiencing a pronounced "clunk" from the front brakes as follows:Whenever I back up and apply the brakes without any noises.  When I put it in drive, the first time I hit the brakes going forward they "clunk". It's coming from both sides.  This noise is not heard in any of my other Vibes. Are the front brakes loose in some way? Can the pads be sized incorrectly?  The dealer says it's nothing to be concerned about.  I have my doubts.  It's still under warranty.  Any ideas?
				Re: Front disc brakes "clunk" (richard_v)
				Posted: Thu Jul 16, 2009 9:01 am
				by keithvibe
				take it to an independent shop and tell them the concern. To have them simply look at the problem shouldn't cost you a dime.But from the sounds of it it could be various things. Anything from a shim that is missing, to the lack of grease on the shims, a pad that doesn't belong on the car. Has the brakes ever been worked on recently?
				Posted: Thu Jul 16, 2009 10:19 am
				by WaveAction
				i have the same problem..ever since i lowered the car it does it the first time i brake..but after that it's fine..we have a few corolla's at work and they do the same thing..i was beginning to think it was a toyota thing..but i dont know
				Posted: Thu Jul 16, 2009 3:54 pm
				by Sublimewind
				it's possible that the slide clips are worn out (not likely), the pads are likely shifting.. It really shouldn't be a concern, but some lube might be on order... Welcome to GV BTW!!We do have a suspension and brake section, for future reference..
				Posted: Thu Jul 16, 2009 8:36 pm
				by bull77
				i hear the same thing here -- only happens once after i reverse and then put it in drive. I asked the dealer and they said it was normal as long as it doesn't clunk at every stop. :/
				Posted: Thu Jul 16, 2009 9:00 pm
				by renate
				Same thing with mine.Only after I put it in reverse and then in drive.The first time I brake after that I hear the "clunck".
				Re:  (renate)
				Posted: Thu Jul 16, 2009 10:38 pm
				by Tubaryan12
				Quote, originally posted by renate »Same thing with mine.Only after I put it in reverse and then in drive.The first time I brake after that I hear the "clunck".Same here. I think it's normal.  I had the same brake pads on the car for over 80k miles.
				Re:  (Tubaryan12)
				Posted: Thu Jul 16, 2009 10:53 pm
				by Kamikaze
				Mines does the same thing. good to hear I'm not alone... There's nothing loose in th pads or clips, they are tight, must just be something within the car... I wonder if the Matrix's do it too, if the Corolla's do, I'd assume the same thing with the Matrix's.
				Re:  (Kamikaze)
				Posted: Fri Jul 17, 2009 1:11 am
				by silvrhawk7
				this may not be relivent, however what are the outside temps when this happens?? I seem to get something similar to this the early am if it is cold or wet outside.....
				Re:  (silvrhawk7)
				Posted: Fri Jul 17, 2009 1:14 am
				by Kamikaze
				Quote, originally posted by silvrhawk7 »this may not be relivent, however what are the outside temps when this happens?? I seem to get something similar to this the early am if it is cold or wet outside.....Doesn't matter... I've had it happen in the mornings when it's 30 degrees out and in the summer when it's been 90 degrees out.. but it seems to only really happen when I back up and then go fwd... also rain or shine... (so everytime I park my car in my garage because I back into my garage)
				Posted: Fri Jul 17, 2009 6:46 am
				by renate
				Agreed the outside temp doesn"t matter.The only time it does happen is everytime after I have used reverse and then go forward,the first time I hit the brakes.....clunk.But I don' tremember it happening when I first bought the car,so I am going to ask the dealer next time I go in for an oil change.
				Posted: Sun Jul 19, 2009 1:04 pm
				by fiveoh
				My 2007 does this...This is "normal."  I had a 2001 Civic EX that did the same thing....When you replace the front brake pads, it might go away (hopefully).
				Re:  (bull77)
				Posted: Tue Jul 21, 2009 5:03 am
				by richard_v
				Thanks for the head's up on the right section to go to.  It's my first time in one of these forums.  So far I am quite please with what I see.Rick
