Proform shift light wiring question
Posted: Mon May 12, 2003 5:03 am
by Nervous_Dog
Someone has to have the Proform shift light listed in the "Mods" section on Genvibe. I am thinking about getting one but I'm not sure about hooking it up. What wire do you splice the green wire into? Any help is appreciated.Thanks,ND
Re: Proform shift light wiring question (Nervous_Dog)
Posted: Wed Jul 09, 2003 4:44 am
by Nervous_Dog
Hello? Is this thing on?
Posted: Wed Jul 09, 2003 5:41 am
by satur9
i dont have one one the vibe but on my old pontiac i spliced into the tach output wire on the ecu youll need a pin out wiring diagram(i think someone posted one here a while back)or if have a multimeter pop off the instrument panel and see which wire goes to the tach its voltage which change when you step on and off the gas
Posted: Wed Jul 09, 2003 5:50 am
by ragingfish
I know ragecyr from matrixowners.com has a shift light on his automatic...might wanna ask him where he attached his to...not sure if it's the same brand, but I'd imagine they all install similarly...
Re: Proform shift light wiring question (ragingfish)
Posted: Wed Jul 09, 2003 6:36 am
by cohocarl
quote:...has a shift light on his automatic....
Re: Proform shift light wiring question (cohocarl)
Posted: Wed Jul 09, 2003 6:37 am
by ragingfish
No kidding. He does. He said you can actually get an extra 500 RPM by manually shifting the automatic...
Re: Proform shift light wiring question (silverawd26)
Posted: Wed Jul 09, 2003 9:50 am
by dmitri
Autos are very beneficial in racing. Most fast cars at the track etc. are automatic simply because they get of the line quicker and because an auto shifts alot faster. If you put an auto in first you can bring it up to any RPM you want, and then manually shift it while the clutch is automatic. I have a trw trans (auto) in my 79 malibu with a b&m shifter and its good for low 12's to high 11 second runs. I just hold the brake and bring the RPMs up then let go to launch.
Posted: Wed Jul 09, 2003 10:44 am
by ragingfish
As previously mentioned, ragecyr told me you can actually get extra RPM's out of each gear by manually upshifting...the car always upshifts a bit early he said...the light gets him that extra bit of power...
Posted: Wed Jul 09, 2003 11:14 am
by NovaResource
quote:but there is no reason to have a shift light on a Automatic Trans.Yes there is in drag racing. Most people who run autos in drag racing use a shift light to shift at the exact RPM they want. Allowing the trans to shift on it's own isn't always the fastest way down the track. Most autos shift too early for the best ET.
Re: Proform shift light wiring question (NovaResource)
Posted: Wed Jul 09, 2003 11:15 am
by ragingfish
Posted: Wed Jul 09, 2003 12:07 pm
by NovaResource
ET = elapsed time
Posted: Wed Jul 09, 2003 12:24 pm
by ragingfish
thanks. brain fart.
Posted: Thu Jul 10, 2003 3:41 am
by dmitri
sure there is a point of having a light on a street car...maybe he likes racing and just wants to be reminded when to shift. Also, it looks cool btw, i have an accel shift light on my malibu and love it.
Posted: Thu Jul 10, 2003 11:53 pm
by Sub-Vibe-R
quote:Someone has to have the Proform shift light listed in the "Mods" section on Genvibe. I am thinking about getting one but I'm not sure about hooking it up. What wire do you splice the green wire into? Any help is appreciated.Thanks,NDOk back to topic.The easiest way to plug your shift light to the tach is going directly to the ecm, at the passanger side.The tach is located in the lowest row of wiring (the 4th one) and if I remember well, it is the 4th wire (for sure it is in the 10 1st wire).The tach is a back wire with silver dot.
Re: Proform shift light wiring question (Sub-Vibe-R)
Posted: Fri Jul 11, 2003 1:08 am
by Nervous_Dog
Thanks! That's the info I needed
Posted: Fri Jul 11, 2003 1:33 am
by Sub-Vibe-R
I'm preatty sure of this info, but just in case, test the wire with a test light before completing the connection.If is always safier to check 2 times before connecting something.
Posted: Fri Jul 11, 2003 1:55 am
by Nervous_Dog
Test twice, connect once. Gotcha!Thanks again
