Pitted headlights...
Posted: Tue Jun 30, 2009 11:26 am
by W2ZXN
Does anyone know if there is a way to fix up the pitted headlights of my '03 base vibe. I've heard of plastic buffing compounds and such, but have not heard any success stories using these products on headlight casings. I wanted to replace them, but I really don't have the money for that right now. Any suggestions?
Re: Pitted headlights... (W2ZXN)
Posted: Tue Jun 30, 2009 11:39 am
by KrazyB
Can you post a pic and are they actually pitted really bad or just scratched?
Re: Pitted headlights... (KrazyB)
Posted: Tue Jun 30, 2009 1:09 pm
by Raven
The headlights on my '92 Subaru SVX were so hazy you couldn't see the bulbs inside. I had to drive with my high beams on just to see at night. I polished them with Meguiar's PlastX and the difference is literally night and day. If you have large deep pits it may be necessary to start out with finer and finer wet sanding and finish with PlastX. To help maintain the clarity you can spray them with a couple of coats of clearcoat.
Posted: Wed Jul 01, 2009 6:22 am
by keithvibe
two words Meguiar's PlastXO and some good elbow grease.They will look like new in no time.I found if i put the buffer in a drill and used the drill on the headlights they come up nicely
Posted: Wed Jul 01, 2009 7:49 am
by vibolista
I just did this for my son's 05 Vibe on Sunday. PlastX, a clean micro fiber rag, and about 15 minutes per light. Had him turn on the headlights when I finished the driver's side. What a difference it made. Bigger pits = more time. Give it a try and tell us how it worked.Sanded roads in Winter are the main cause of this damage in our area. Stay as far away from the car in front of you as you can and watch out for fast moving big rigs heading at you in the opposite lane. These things scoop up and drag along huge amounts of small rocks that will pit lights, paint surfaces and windshields or worse in one pass.
Posted: Wed Jul 01, 2009 1:39 pm
by JohnC
I have fixed many of these headlights, it is very easy. You will need a sheet each of 1500,2000 & 2500 grit sandpaper, some white and red jewelers gouge, and a 6-8" buffing wheel with drill motor atachment.First you wet sand in straight lines back and forth and up and down. Keep it wet and do not sand in a circular motion. Start with the 1500 and work your way up to the smoothest (2500), then first using the red (then the white) jewelers gouge buff the lenses just like you sanded them. After you have done a couple you will get the hang of it and it will just take a few minutes to have new looking headlight lenses.BTW the old school sealed beam hallogen headlights never had this problem.
Re: Pitted headlights... (JohnC)
Posted: Wed Jul 01, 2009 7:47 pm
by keithvibe
Quote, originally posted by JohnC »BTW the old school sealed beam hallogen headlights never had this problem.Well thats because they were made of glass not plastic LOL
Posted: Wed Jul 01, 2009 10:57 pm
by lowincash
yah i did that wet sanding thing on my accord headlight once. it was kinda scary as i see the lens get hazier and hazier lol but once i put the plasticx on and buff it out they came out looking pretty good. i did it by hand so i was sore the next day =P
Posted: Fri Jul 31, 2009 7:04 pm
by joejoev
whelan posted a nice walk through here:
http://forums.genvibe.com/zerothread?id=32206I could not find 2500 grit sandpaper to save my life when I did my 2004's headlights. I used 1000, 1500, and 2000 grits and the results were awesome.
