Still trying to figure out the dead light...
Posted: Mon Jun 22, 2009 11:54 pm
by ThunderRoad
Couple of months ago I posted about the driver's side low beam light being dead. I've checked and tested and can't find the problem...BUT the other day, we saw another Vibe around town and it had the SAME light out.So, there is more than just us having this problem.How can we cross-check to see if there is a TSB about this issue?
Posted: Tue Jun 23, 2009 11:13 pm
by Sublimewind
How far have you followed the harness into the car? Have you found the grounds for the lights.. Fuses? Corrosion on the terminal right at the bulb?? I had an Astro that I had to take a screwdriver to the bulb plug to burnish out the corrosion enough for it to make contact.. I'd be going down the orad and it would go out... I'd stop get out, thiump it and it would come back on...
Re: Still trying to figure out the dead light... (ThunderRoad)
Posted: Fri Jul 03, 2009 6:13 am
by keithvibe
there aren't any tsb's for the headlights. Your just a padiddle.
