S/C grinding .... again
Posted: Fri Jun 19, 2009 6:19 am
by 4azdmunky
So, now that I've had the car running for a little over a month without any issues, the S/C started grinding again. Its not as bad as last time where it sounded like a rock tumbler, but each day it gets a little worse. Not looking forward to another $800 rebuild bill on this thing, anyone know how to make these things more reliable? Does anyone know if Magnuson has TRD nose assemblies? Their web site doesnt say.How about an oil change? Does it have to have S/C oil or would Royal Purple Gear Oil work?
Re: S/C grinding .... again (4azdmunky)
Posted: Fri Jun 19, 2009 7:26 am
by satur9
mabey try gatorback belt with slightly less belt tension. or fab up a bracket to hold the nose up
Re: S/C grinding .... again (satur9)
Posted: Fri Jun 19, 2009 11:28 am
by 4azdmunky
I already have a gatorback belt, I was wondering if it was 1/2 a rib off or something and was causing a vibration. I'll check that out in the morning.Thanks!
Posted: Fri Jun 19, 2009 12:40 pm
by DiveNut
Is it grinding when you start it up or when you are under load/in boost? A little noise at idle is normal. Especially until you reach operating temperature. However, it should smooth out when your RPMs get above about 1200-1500 RPM or so. Doe she smooth out at idle when your temps get up? If so, I believe you are OK.
Re: S/C grinding .... again (DiveNut)
Posted: Sat Jun 20, 2009 2:50 am
by 4azdmunky
lucked out, turned out the pulley was loose. A little LOC-Tight and a socket, and its all fixed.
Posted: Sun Jun 21, 2009 12:57 am
by DiveNut
Quote, originally posted by 4azdmunky »lucked out, turned out the pulley was loose. A little LOC-Tight and a socket, and its all fixed.Good deal!
Posted: Tue Jun 23, 2009 8:20 am
by Petrucci914
Quote, originally posted by 4azdmunky »I already have a gatorback belt, I was wondering if it was 1/2 a rib off or something and was causing a vibration. I'll check that out in the morning.Thanks!Don't use Gatorback belts on the SC'er. Trust me.
Re: S/C grinding .... again (Petrucci914)
Posted: Wed Jun 24, 2009 9:45 pm
by 4azdmunky
Hmmm. what happened?
