Which is the correct off set ?
Posted: Mon Jun 08, 2009 11:16 pm
by petervibe
Which is the correct off set for after market alloys ? I found 16" Celica GT wheels , the seller states they have an off set of 55. 16x 7 Would that fit ? Please let me know someone. So I know if i should buy them. thanks,Peter
Posted: Mon Jun 08, 2009 11:19 pm
by lovemyraffe
I don't know the offset, the wheels I just put on have an offset of 45mm. Double check the bolt pattern. I don't think the offset will be a problem.
Posted: Mon Jun 08, 2009 11:39 pm
by petervibe
I am told that Toyota uses 5x100 pattern. Thats the same as the Vibe, right ?
Re: (petervibe)
Posted: Tue Jun 09, 2009 12:57 am
by Kamikaze
Quote, originally posted by petervibe »I am told that Toyota uses 5x100 pattern. Thats the same as the Vibe, right ? If you have a 03-08 Vibe then yes the 5x100 is correct.
Posted: Tue Jun 09, 2009 1:36 am
by petervibe
Thank you very much !! yes it is an 06 2WD.
Re: (petervibe)
Posted: Thu Jun 11, 2009 11:43 am
by vibolista
Vibe/Matrix offsets for the 03 thru 08s range from 39 to 45mm. The 16 inch steel and alloy wheels are 39mm and the 17 inch alloy has a 45mm offset. Don't know if they changed offsets for the 09 mondel year. A 55mm offset would put the outside edge of the wheel about 10mm farther inside the wheel well than the 45mm. I bought a 38mm offset 17 inch wheel to bring the tire and wheel out to the edge of the Vibe wheel well lip. Ended up almost flush... just a few mms from the edge.
