TWM Short Shifter question ?
Posted: Mon Jun 01, 2009 7:00 am
by Sull
I installed my short shifter today and I recall reading in the instructions that the bend in the shifter should be pointing towards the front of the vehicle ... I think .. Anyhow to me it seems that when the shifter is in neutral, 2 and 4 it sits quite forward to the front of the vehicle , just wondering if I need to switch the shifter bar thingy the other way around ... what do you think
Posted: Mon Jun 01, 2009 8:56 am
by engineertwin2
You are correct that the TWM installation instructions indicate that the bend in the shifter should be pointed towards the front of the car (see Step 15). This should be similar to the original shifter shaft installation.If you have problems or concerns, I'd give TWM a call. I don't have the short shifter (I wish), but have heard they have excellent customer service.
Re: TWM Short Shifter question ? (Sull)
Posted: Mon Jun 01, 2009 9:43 am
by Herb
Here's a shot from my install
Posted: Mon Jun 01, 2009 11:15 am
by Sull
I know what the instructions say... I read them, just to stupid to figure it out haha..Herb I cannot even tell which way it bends by that pic. Do you have any more or do you recall if you had to switch the shifter shaft the other way around ?? Just that when in the 2nd and 4th I feel that should be neutral ??Herb do you have stock shifter or TWM weighted one ?
Posted: Mon Jun 01, 2009 11:58 am
by Sull
Herb do me a quick favor if you will ?Quickly just unscrew you shift knob and pull off the boot. Is the shaft sticking directly up to the sky ?? Mine is. Probably right after looking at it with the shifter knob off
Re: (Sull)
Posted: Mon Jun 01, 2009 2:01 pm
by Herb
Here's the shot you requested And here's a shot with the weighted Desert Eagle knob Although I did buy the weighted knob, I found that in Alberta climates it really isn't all that great to use. In the winter grabbing a stainless steel knob that's like -25 degrees C is not very comfortable.That and since I have a 6 speed I'm worried that any service guy would probably shove it into 6th thinking he's going into reverse so I've gone back to the stock knob for now.And as a reference, this is what the stock shifter looks like
Posted: Tue Jun 02, 2009 12:50 am
by Sull
Great thanks!!! That's exactly how mine looks, just wanted to be sure...In all honesty do you think a "service guy" would actually look at the knob or just slam it in gear ?I have changed my sitting position a little and thinking about going back to the gym for some arm workouts hahaha jk, but seriously the shifter is much harder now and I think I will invest in getting a TWM knob. And your probably right in the winter I would have to take it off or wear gloves every time I drive because yes it will be cold, the knob never seems to warm up..PS. Have you or do you know of a Dyno in your area, I am trying to source one out in the Vancouver area or even where your at .. same distance either way...
Re: (Sull)
Posted: Tue Jun 02, 2009 10:02 am
by Herb
Quote, originally posted by Sull »In all honesty do you think a "service guy" would actually look at the knob or just slam it in gear ?Well it gives me a bit of piece of mind I think.Quote »I have changed my sitting position a little and thinking about going back to the gym for some arm workouts hahaha jk, but seriously the shifter is much harder now and I think I will invest in getting a TWM knob.It was tough initially with the stock knob, but it didn't take me too long to get used to it.Quote »And your probably right in the winter I would have to take it off or wear gloves every time I drive because yes it will be cold, the knob never seems to warm up..I threw my tuque over it for the first winter I had it. I guess I should have invested in some gloves.I chose the Desert Eagle knob because it was the heaviest that TWM had. If you are going to order from them you should also get the bronze shifter bushings to replace the stock rubber onesQuote »PS. Have you or do you know of a Dyno in your area, I am trying to source one out in the Vancouver area or even where your at .. same distance either way... I'd have to look it up, but I'm sure both Vancouver and Calgary should have at least one dyno
Posted: Tue Jun 02, 2009 1:53 pm
by Sull
Cool. I was looking at the TWM Piston, it's a little lighter than yours. I will most definitely get the bronzoil bushings. Were they hard to install ?I am sure the shifter will feel normal again soon No worries on the dyno, I am just looking for someone who knows of one and what kind of costs.
Re: (Sull)
Posted: Tue Jun 02, 2009 10:52 pm
by Herb
Quote, originally posted by Sull »Cool. I was looking at the TWM Piston, it's a little lighter than yours. I will most definitely get the bronzoil bushings. Were they hard to install?Not for me, mostly because everything that I would have had to remove to install it was already gone since I have a cold air intake. You'll have to remove your airbox to access the area, but after that it's pretty easy.Of course if you were to add a cold air intake or short ram intake this would be a good time to do it. I think you'll notice a nice increase in performance once you do, especially since you already have a Magnaflow. Take a look at Cosmo Racing, they have the best deal around. Quote »I am sure the shifter will feel normal again soon I think part of why it might feel unusual is because the whole system sits closer to the dash. The stock shifter unit sits about an inch further from the dash. Either way you'll get used to it in short order.
Posted: Wed Jun 03, 2009 12:51 am
by Sull
Hahaha I forgot to add my K&N short ram intake to my list of mods ( fixed now ) I took a look under the hood and saw what needs to be done, I will get those when I get the shifter knob, but I think I am gonna get a air/fuel wideband so I can play with A/F on my camcon ( it's is in the mail ).For some odd reason I really felt I wanted to redline my car yesterday, in first gear I hit the governor or w/e and the car totally shutdown for a split second hahah
Posted: Wed Jun 03, 2009 5:53 am
by wyatt89
Do you guys feel that the shifter helps? I've got an 04 gt and the shifter has to be one of the sloppiest ones I've ever felt, it's ridiculously imprecise feeling. The throw doesn't bother me but do you think brass bushings would help cure that "shifter slop"? Is the shifter with the price?
Re: (wyatt89)
Posted: Wed Jun 03, 2009 6:56 am
by Herb
Quote, originally posted by wyatt89 »Do you guys feel that the shifter helps? I've got an 04 gt and the shifter has to be one of the sloppiest ones I've ever felt, it's ridiculously imprecise feeling. The throw doesn't bother me but do you think brass bushings would help cure that "shifter slop"? Is the shifter with the price?Well as you can see above, the frame of the stock shifter is made of plastic which flexes, plus the stock rubber bushings all add to the sloppiness. This is one of my favorite mods for sure, and one of the easiest. No regrets, and definitely worth the cost for me.
