Brake squeal
Posted: Mon May 25, 2009 11:38 am
by SublimeVibe
I put on some new brake pads and rotors and the brakes still squeal any help.
Re: Brake squeal (SublimeVibe)
Posted: Mon May 25, 2009 8:26 pm
by scherry2
did you put on ceramic pads? I put on ceramic pads but didn't do anything with the rotors and they squeal when coming to a stop. I think I need to turn my rotors so the surface isn't so smooth.
Posted: Mon May 25, 2009 11:02 pm
by Sublimewind
Did you apply any squeal stop to the back of the pad? It's a paste like compound..
Posted: Tue May 26, 2009 9:18 am
by SublimeVibe
I put the stuff that came with the padson.They were Monroe .
Posted: Tue May 26, 2009 1:12 pm
by DavidPIL
Does it make the noise all the time? There are some solutions here... http://my.is/forums/f89/soluti...2886/ I had the "Rotor groove noise" after putting on new EBC rotors. My solution was somewhat different than theirs though. I ever so slightly bent the backing plate away from the rotor's travel. I also did some minor grinding but to the backing plate where I saw it was rubbing - not to the rotor. Dave
Re: (Sublimewind)
Posted: Tue May 26, 2009 7:42 pm
by scherry2
Quote, originally posted by Sublimewind »Did you apply any squeal stop to the back of the pad? It's a paste like compound.. I know I did
Re: Brake squeal (scherry2)
Posted: Tue May 26, 2009 10:22 pm
by Sublimewind
Quote, originally posted by scherry2 »did you put on ceramic pads? I put on ceramic pads but didn't do anything with the rotors and they squeal when coming to a stop. I think I need to turn my rotors so the surface isn't so smooth. That might not be a bad idea... EBC pads come with a "break-in coating" on the pad surface... You can see it's just a paste with some grit in it to break away that shiny surface in the first few stops.. that helps a lot in proper bedding of the pads.. Have you ever looked at a proper bedding and seasoning procedure for brakes? There is a LOT more to it than most know and it feels a lot more extreme than it really is, while you are doing it.. (you have to smoke the brakes basically) Hit up baer brakes, and look at the tech sections... very informative and I believe in it 100%... I direct this at you as well SublimeVibe.. (I dig the name..lol) I don't remember if out cars have backing plates/shims for the pads? If so, some stop squeal between them and the pad would help... If not, I always us globs, instead of spreading it across the pad.. Heck, usually I use my Sil-Glide brake grease (which reminds me, i'm going to NAPA today, I need a new tube)
Posted: Fri Jun 05, 2009 6:48 am
by SublimeVibe
Was thinking ,could it be the wheel bearings squealing as I put pressure on the frontend as I slow down.Today they were really bad they seem to squeal even more the faster I'm going then coming to a stop I do not apply max pressure on the brakes .Man I'm going crazzzzzy with this s$#@t and I only get to use the car when the wifes at work and on weekends.
