Which plug is the oil pan plug?
Posted: Sat May 23, 2009 9:08 am
by rollin
I see two different drain plugs, is the oil drain plug on the left side, or the one in the middle of the car? I would think it is the plug on the same side as the oil filter, correct????
Re: Which plug is the oil pan plug? (rollin)
Posted: Sat May 23, 2009 9:17 am
by keithvibe
for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.
Re: Which plug is the oil pan plug? (keithvibe)
Posted: Sat May 23, 2009 9:21 am
by rollin
it's an 04. And I thought it was the one on the passenger side...
Posted: Sat May 23, 2009 4:37 pm
by tribalman
from memory, it should be in the middle. right inline with the filter.
Posted: Sat May 23, 2009 9:08 pm
by zionzr2
Quote, originally posted by keithvibe »for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.+1
Posted: Mon Jun 01, 2009 2:50 pm
by hbutko
Yes its the plug nearest the passenger side. Your oil pan is shaped like a T. the oil plug has a 14mm head.
Re: Which plug is the oil pan plug? (hbutko)
Posted: Tue Jun 02, 2009 12:38 pm
by Digger
And think, I have been useing a 9/16 for 4 years now. never thought it was metric.
Re: Which plug is the oil pan plug? (Digger)
Posted: Wed Jun 03, 2009 5:37 am
by keithvibe
Quote, originally posted by Digger »And think, I have been useing a 9/16 for 4 years now. never thought it was metric. HAHAthe trans plug is a 10mm allen just in case people wanted to know
Posted: Wed Jun 03, 2009 5:45 am
by wyatt89
Quote, originally posted by keithvibe »HAHAthe trans plug is a 10mm allen just in case people wanted to knowThat's bizarre, most cars have a 1/2" square hole so you can just stick a breaker bar in there if it's tough to get out It's quite nice.
