Wiring Diagram
Posted: Fri May 22, 2009 2:29 am
by techren
Does anyone happen to have a diagram showing the hatch glass release? The button on my dash stopped working and I would like to fix it. Already tested the switch it is OK.Any help here would be great.Thanks!!
Posted: Fri May 22, 2009 11:49 pm
by Sublimewind
What do you need to see? If you pull the rear hatch panel off, it's right there... You would want to check the line there to see if you are getting 12v and if so, it's likely the solenoid.. pretty straight forward..
Re: (Sublimewind)
Posted: Tue May 26, 2009 9:21 am
by techren
I need the routing from the button on the dash to the control module. I installed it myself when I got the car. At the time I had the diagram but I seem to have lost it. It worked for a long time but I think one of the wires, there are only two running to the switch, may have come loose.It is rather difficult to see things up under the dash so the diagram would tell me where to focus.
