Thanks Magoo, by golly I found it, there is a matrix of three figure codes, and it appears the last two set of three, out of about 46, are the ones.  But how did you know that?  Also, I looked on a website that said the two trim colors for 07 were black and slate.  This one has the medium dark gray codes -- funny, it looked kinda black to me and I would have at least guess it was the dark gray. Confusing, don't you think?Thanks again, interested in any other input.  In fact there are a few more parts I need.  The little dealer I bought it from said they can get what I need for 20% discount from the dealer IF I get the parts numbers first, from the dealer.What I need--roof trim, left side, it is rubber/vinyl which appears to run all the way under the roof rack.--rear end cap for passenger side roof rack, the current one is held on with duct tape and I presume it is broken.  I'd like to put things back to stock as much as possible.--one plastic "hinge pin"(?) on the center console lid is broken, making the lid very wobbly.  this device has a screw through it, it and the one on the other side hold the lid and its "hinge" on to the console.  The dealer couldn't find this on the parts diagram, weird.  I am going to take the vehicle by there and have him look at it.  If I have to buy the whole assembly, I might try to switch to the matrix double lid.  Meanwhile, I am not sure if it is part number 13 on this page:
http://www.trademotion.com/par...gid=2--I want to order stock OEM floormats too, might as well get the disount on those as well, right?OK please advise! ! !  Is there some other place to get those pesky part numbers?
