Growling & vibration - Puzzling (Edit: FIxed)
Posted: Fri May 15, 2009 9:36 pm
04 Vibe with 51000kms, auto. Runs very well with no codes, except that a bad growling/vibration has appeared only at idle when almost or completely stopped, in drive. Doesn't do it in neutral or reverse, or when at speed. I think it's a heat shield because of the intermittent clanging and squeaking near the firewall, but growling and solid vibration through the floorboard is something I've never experienced from just a loose shield... Any ideas? It appeared after I took the car for a test run on new wheels, and I stretched it's legs rpm-wise, something that never happens otherwise (wife's car)
