What are these orange spots behind my rims?
Posted: Sat May 09, 2009 8:00 am
by ktyure
I recently purchased a new 09 vibe gt a week ago and I am now noticing that there are some orange spots behind my rim. I don't know much about cars, so I can't say what the item is but i'll guess it's the brakes? I was wondering if the orange spots are rust and if so what can i do to remove and prevent this? It has been raining every day since I purchased my car so maybe that is a factor? Any tips or information will help. Thanks.
Re: What are these orange spots behind my rims? (ktyure)
Posted: Sat May 09, 2009 9:43 am
by VforVIBE
If it is indeed rust on the disk brake rotor, do not worry, this is normal and will go away after you apply the brakes.
Re: What are these orange spots behind my rims? (VforVIBE)
Posted: Sat May 09, 2009 10:02 am
by ou.grizzly
Quote, originally posted by VforVIBE »If it is indeed rust on the disk brake rotor, do not worry, this is normal and will go away after you apply the brakes. ^^^This.If they are ON your rims, clay bar them. It should remove any oxidization.
Re: What are these orange spots behind my rims? (ou.grizzly)
Posted: Sat May 09, 2009 2:27 pm
by ktyure
Thanks for the replies. I didn't know it was called a brake disc rotator. So you mean the next time I drive my car and I press on the brakes, the orange spots will come off? Thanks for the help. I was really worried.
Posted: Sat May 09, 2009 6:53 pm
by VforVIBE
Quote, originally posted by ktyure »Thanks for the replies. I didn't know it was called a brake disc rotator. So you mean the next time I drive my car and I press on the brakes, the orange spots will come off? Thanks for the help. I was really worried. No worries I've seen Corvettes sitting on the dealer's lot after some rain with this same problem. Yes they should come off with normal driving.
Posted: Sat May 09, 2009 6:58 pm
by bodhi_tree777
No worries. I just put new front brake rotors on, and its amazing how quickly they start to show rust.
Re: What are these orange spots behind my rims? (bodhi_tree777)
Posted: Mon May 11, 2009 1:42 am
by Whelan
If your car sits in rain or damp, muggy conditions for a period of time with little use, rust will develop naturally on that part of the car. You may notice when you first use the brakes a couple of times they seem to have a rougher almost grind effect. It is the rust being removed, no worries, happens all the time.
