Matrix 16" OEM Wheels?
Posted: Wed May 06, 2009 6:00 am
by RXeckless
Will 2006 Toyota Matrix OEM Rims fit a 2004 Pontiac Vibe?Every thing is the same Bolt, Offset but center bore on vibe's is 57.1 mm and the Matrix is 54.1 mm?Has Anyone mounted Matrix wheels on a Vibe? Got a deal on them with 2 year old rubber GY RSA's 500 CANThanks for any help in advance!
Re: Matrix 16" OEM Wheels? (RXeckless)
Posted: Wed May 06, 2009 8:03 am
by RIT
Yep - all of the wheel parts are interchangable from Matrix to Vibe.
Re: Matrix 16" OEM Wheels? (RIT)
Posted: Wed May 06, 2009 8:24 am
by RXeckless
Thanks for your input, its for my wife's car she has 16' steelies w/hub caps now with her winters.Is there some sort of centering ring on the wheel? I drive a 2007 RX-8 with two sets of matching rim one summer/one winter.
Posted: Thu May 07, 2009 1:37 am
by sk8r78
I just recently discovered that the true centerbore for the Trix is 54.060. I don't know why a Vibe would be different, unless you are measuring from the front for the center cap and not from the back at the hub. If there truely is a difference then a hub centric ring can probably be purchased.
