map lights not coming on when the door opened
Posted: Tue May 05, 2009 12:23 am
by tc3drivers
I have a CDN 2005 Vibe with the power pkg. The 2 map lights under the mirror stopped coming on when the door is opened. The light in the hatch still comes on when the doors are opened though. The map lights work when you use the switch on the light and the rotary switch on the dash. Thought I'd post here before asking the dealer because I get tired of the blank faces there with these types of problems.
Re: map lights not coming on when the door opened (tc3drivers)
Posted: Tue May 05, 2009 3:38 am
by breezd
On my 03, I do not have the lights on the mirror... but on the front lights (with the moonroof controls on the unit), have never (since I have owned it) come on with the doors open. The light only turns on by pressing the button to turn it on. The center lights (behind moonroof) and rear lights (hatch area) do turn on with the doors open.But, since mine is '03 and US, the '05 and/or Mirror map lights and/or CDN may be different.
Posted: Tue May 05, 2009 5:36 am
by prathman
The map lights in the mirror of our '06 also don't come on when the doors are open - and never have. The door switch does control the center dome light and the one in the hatch.
Re: (prathman)
Posted: Tue May 05, 2009 6:06 am
by keithvibe
Quote, originally posted by prathman »The map lights in the mirror of our '06 also don't come on when the doors are open - and never have. The door switch does control the center dome light and the one in the hatch.x2 on my 06 my map lights in the mirror have never come on other than using the switch.
Posted: Tue May 05, 2009 8:41 am
Quote, originally posted by tc3drivers »I have a CDN 2005 Vibe with the power pkg. The 2 map lights under the mirror stopped coming on when the door is opened. .you're sure they used to come on when the door was opened?
Re: map lights not coming on when the door opened (joatmon)
Posted: Tue May 05, 2009 9:04 am
by morbay
This is all really odd, the map lights on the '09 come on when the door is opened. There is a switch there with the lights that have settings of off, door, on, or something similar. I thought this was standard in pretty much every car, as the '05 Malibu I owned previously had the same setup.
