Odd transmission or shifter noise in fifth gear
stagwag86
Post by stagwag86 »
My car is an '05 Vibe, 5 speed with about 70k miles on it. I just noticed in fifth gear that I get a dull buzz/vibration coming from the center of the car under acceleration. The noise goes away if you touch the shifter handle, but comes back when you let it go, and I don't feel any odd vibrations in the handle. It also goes away if you press the clutch pedal in.So, what could be causing a buzz in the shifter handle, only in fifth gear, and only when the engine is under load? Any thoughts?
Re: Odd transmission or shifter noise in fifth gear (stagwag86)
I can't think of anything that would cause that, that would go away when you touch the shifter. How firmly to you need to touch the shifter to make the noise go away?
stagwag86
Re: Odd transmission or shifter noise in fifth gear (joatmon)
Post by stagwag86 »
Doesn't take much, really. Just a little push either forward, left or right. It's not any more bothersome than any other of my vibrations, except that I know what makes this one stop and I don't want to have my hand on the shifter all the time.
Silversn95
Post by Silversn95 »
might just be bushings in the shift linkages wearing out. I would take a look at all connection points and make sure everything is tight.
2009 Pontiac Vibe - 1.8L 5-speed 1SB Carbon Gray Metallic with 20% tint
stagwag86
Post by stagwag86 »
I know this is an old thread that I started a long time ago, but just in case anybody else notices this noise, turns out it was a bearing in my 5-speed transmission beginning to go out. I ended up driving it for another 30k miles until the noise got much louder, then replaced the 5-speed with a 6-speed.
Salsa Guy
Post by Salsa Guy »
Thanks for posting an update!
