New transmission - not engaging
Posted: Sat Apr 04, 2009 12:31 am
by 4azdmunky
So i ended up having to replace my transmission this month. Ordered a low milage transmission from LQK. Drained all the fluid, installed a phantom grip and new pan gasket.Dropped the engine and tranny back in yesterday, however the transmission will not engage any gear (i did get about one revolution of the wheel at one time). I put the 7.3 qts of fluid in, but it doesnt seem to be circulating. Is there some step that I missed to get the fluid to start moving?tried searching but couldnt find anything.
Re: New transmission - not engaging (4azdmunky)
Posted: Sat Apr 04, 2009 12:43 am
by kevera
did you put any fluid in the torque converter??You have an automatic,right?BTW..the pulley works great.
Re: New transmission - not engaging (kevera)
Posted: Sat Apr 04, 2009 1:01 am
by 4azdmunky
Yeah I put a qt in the torque converter.Glad you like the pulley! I'm missing mine, cars been down for a month
Posted: Thu Apr 09, 2009 2:03 am
by 4azdmunky
Ok, I reset the Torque Converter again last night and the transmission still is not engaging. Before I rip this all out again, I noticed that the repair manual states to reset the memory. The TSB's state to use the Toyota Diagnostic Tester Kit to reset for these transmissions. My question is, do I actually need this, or can I just pull the battery cable and discharge any stored power?
Posted: Sat Apr 25, 2009 11:40 am
by 4azdmunky
So it eneded up being a defective oil pump in the transmission. Swapped it out with the one from the transmission i blew, and it works now.it was down for almost 2 months...blah.
