A/C is mad!!!
vitmiro
A/C is mad!!!
Post by vitmiro »
I have 2003 Vibe that has crazy a/c problem. When it starts I have cold air coming out from the driver side outlet and warm air from the central and passenger outlets. After driving for 30 minutes all of the air is warm. Compressor kicks in and fluid was toped. What is a problem??? Thanks.
engineertwin2
Post by engineertwin2 »
Check that the air damper is moving to it's proper position. Do a search - I'm too lazy right now to do it, but you should be able to find it.Also, you charged the A/C, but have you checked it since? Leaks can evacuate pretty quickly...
Re: (engineertwin2)
Quote, originally posted by engineertwin2 »Check that the air damper is moving to it's proper position. you mean http://forums.genvibe.com/zerothread?id=1315 ?vitmiro, any status update?
