Chirpping!
Posted: Wed Mar 25, 2009 6:58 am
by Platinum76
I have the most annoying chirrping noise coming from the drivers side rear of the engine. (05 base model) It only does it at idle. and more so in gear. however the noise will fade and sometimes stop if it idles long enough. Anyone had this problem ?
Re: Chirpping! (Platinum76)
Posted: Wed Mar 25, 2009 7:29 am
by NUBlackshirts
Could it be the Variable Switching Valve? I know mine was more noticeable after I installed the K&N Typhoon intake.
Re: Chirpping! (NUBlackshirts)
Posted: Wed Mar 25, 2009 10:50 am
by THE VIBERATOR
It sounds like a small supercharger, correct? Especially under a full load
Re: Chirpping! (THE VIBERATOR)
Posted: Sat Mar 28, 2009 5:24 am
by Platinum76
yeah "sounds" like a supercharger (dont i wish). lts only at idle. as soon as the rpms go up, even from turning the wheel it stops. and like i said it will fade the longer in idles. i noticed it last summer a lil bit and now its really bad, especially when i'm in a drive through or something. its really annoying >
Posted: Sat Mar 28, 2009 7:55 am
by Truckin1999
How many miles do you have? Do you have an auto tranny? If so check the fluid level and make sure its clean and doesn't stink. Sometimes the pumps will chirp when going bad.
Re: (Truckin1999)
Posted: Sun Mar 29, 2009 4:11 am
by Platinum76
104k. and its auto, fluid is clean. i have drained and filled it about every 20 k. So if the pump is going, does that mean i'll need a new tranny, or is it something that can be repaired?
Posted: Sun Mar 29, 2009 4:49 am
by keithvibe
sure it's chirpping and not a Tick-tick-tick sound? If it's a tick-tick-tick-tick-tick sound that Mostly goes away.. that is normal that the vsv
Re: Chirpping! (keithvibe)
Posted: Sun Mar 29, 2009 6:52 am
by Platinum76
no its definately a chirping/whistling sound.
Posted: Sun Mar 29, 2009 12:13 pm
by Platinum76
and i just noticed that it does not make the noise at all while in reverse.
