Fan Switch not working on any setting but Max...
Posted: Thu Mar 19, 2009 3:10 am
by vibeoh4
My mom's 2004 Vibe has a weird problem. The fan switch/turn dial/ knob does not work any Low/Med settings - only on max. As excited as I am for my mom's A/C and fan to "Only go up to 11" this seems to be like a faulty switch/dial/knob. I was wondering if anyone else had to deal with this kind of thing or if my assumptions are correct for thinking its the switch. It might be something else, let me know what you guys think.
Re: Fan Switch not working on any setting but Max... (vibeoh4)
Posted: Thu Mar 19, 2009 3:24 am
by scherry2
http://forums.genvibe.com/zerothread?id=23496your resistor has quit functioning. at the bottom of the thread above is a picture of where it is located under the dash. hope this helps.
Re: Fan Switch not working on any setting but Max... (scherry2)
Posted: Thu Mar 19, 2009 5:26 am
by 2002sportside
Yup, resistor is done. Check it for any Toyota part numbers, it will be much cheaper there...Twice this week...
Re: Fan Switch not working on any setting but Max... (13Vibe03)
Posted: Thu Mar 19, 2009 6:29 am
by 2002sportside
You're right, they are different. The filter we use is from a Tacoma, wonder if the resistor is too. There might be part numbers under the sticker...Pic in the other thread makes it look like a GM resistor, similar to the disposable ones in Grand Ams...
Posted: Thu Mar 19, 2009 7:50 am
by 2002sportside
Going by the picture in the linked thread, I'm 100% sure the Matrix one won't work. I'm just wondering if there is another Toyota part that matches...
