Max Front speaker depth
Posted: Sat May 03, 2003 5:00 am
by smartin53
OK, quick question. Whats the max depth that the fron speakers can be. I want to make sure I don't buy anything too deep. Also do you need the plastic ring thats on the factory speakers to make it fit properly? Thanks.
Re: Max Front speaker depth (smartin53)
Posted: Sat May 03, 2003 5:40 am
by NovaResource
Welcome to Genvibe. You will notice in the upper right corner of this page, the word "SEARCH". Click on that and you can search the forum for info you are looking for. Since we already discussed this topic, the SEARCH function would have directed you to this thread:
http://forums.genvibe.com/zerothread?id=2757Hope that helps.
Re: Max Front speaker depth (NovaResource)
Posted: Sat May 03, 2003 12:02 pm
by smartin53
Cool thanks, I did run a search but must have missed that one. Got another question now. Sort of a placement/preference question. I have a set of Kenwood KFC-1677 speakers and and considering getting either the Kenwood Excelon KFC-XR601 or KFC-X168 speakers. Question is which should I get and which set should go in the front and which go in the rear or does it really even matter. All the speaker specs are listed at
http://www.kenwoodusa.com/product/produ ... tTypeId=44 . Any recommendations would be appreciated.
Posted: Sat May 03, 2003 3:49 pm
by cohocarl
If you use the stock speaker "shell" you'll need a speaker with a max mounting depth of 2 5/16th in. for the front. The rear can take a speaker with over 3 1/2" depth. My fronts are 165mm (6 3/4") and rears are 6 1/2. Here's a link to some pics of my speaker install if you are going to do it yourself.:
http://forums.genvibe.com/zerothread?id=785
Re: Max Front speaker depth (cohocarl)
Posted: Mon May 05, 2003 2:42 pm
by smartin53
I know the general word is that 2-5/16" depth is the norm for the front speakers but could 2.5" depth speakers fit also? I'm looking at some JBL midbrange speakers and want to see if they fit. Thanks.
Posted: Mon May 05, 2003 5:32 pm
by cohocarl
quote:I know the general word is that 2-5/16" depth is the norm for the front speakers but could 2.5" depth speakers fit also?I think the window would hit it on it's way down if mounted in the old speaker casing. You may be able to put an additional 1/4" spacer in there to pull the speaker out a little further, but then the door shell may not fit right.
