A/C condenser repair
Posted: Thu Mar 12, 2009 3:56 am
by liftaddict
I have a small leak in my AC condenser. The other day I was in Rite-Aid and I noticed this product (can't remember the name) which claimed that when sprayed into the AC system, replenishes the AC coolant, as well as seal any leaks. Before I throw down my $20 for this stuff, I was wondering if anyone has any experience with this. Did it work? Any input will be appreciated. Thanks.
Posted: Thu Mar 12, 2009 4:42 am
by Sublimewind
Do you have ANY A/C right now?? If not, it likely won't help you... once there is a large enough leak, it kills the dryer and the system... If you still have some working A/C you might get away cheap..
Re: A/C condenser repair (liftaddict)
Posted: Thu Mar 12, 2009 5:59 am
by ProtonXX
http://forums.genvibe.com/zero...47007There are 4 screws. 3 Holding the compressor & 1 holding the Hose. I had terrible luck removing the A/C from the top of the car & had to take it out from the bottom with the help of a lift.Easy DIY project if u got a way to lift the car & get under it. The 2 vacuums I was cheated on was $35 and $60. Both left my lines pressurized.
