06 Vibe w/15-in Subaru steel rims - is offset difference an issue?
Posted: Sun Feb 15, 2009 1:54 am
by skeezix
My question is whether the difference in wheel offset is likely to cause any problems with steering or tire wear. Anyone have any experience with this?I have a set of snow tires mounted on 15-in steel rims. (Tires are185/65 x 15 - same diameter as the stock Vibe tire on 16-in rim).The Vibe wheel has 38 mm offset, the Subie wheel has 57 mm. The net change to track width is about 30 mm or 1.25 in, which seems quite a bit.
Posted: Sun Feb 15, 2009 3:45 am
by AKLGT
I don't see how it would. I went from 53 mm to 30 mm offset for a concave look. if you're going backwards and from 38 mm to 57 mm, then it shouldn't matter too much. I mean, people get larger width wheels and tires all the time. as long as it clears your brakes and drums or cause any rubbing, I don't see why it would matter. mainly the diameter of the wheel would be more pertinent. However, i'm no tire expert, so maybe someone else wants to add their expertise of tire knowledge.
Re: Wheel offset
Posted: Sun Feb 15, 2009 7:44 am
by skeezix
Re: 06 Vibe w/15-in Subaru steel rims - is offset difference an issue? (skeezix)
Posted: Sun Feb 15, 2009 7:59 am
by Raven
Actually 195/65/15 is the recommended size (.45% bigger). 185 is smaller (1.75%). You're getting into a much lower load capacity also.
Posted: Sun Feb 15, 2009 10:11 am
by Sublimewind
My '03 with Subaru fitment wheels from my old Impreza, no issue so far and this is the second season.. The brakes clear..
Posted: Sun Feb 15, 2009 10:20 am
by AKLGT
oh duh! i had some 15's off an old celica on my Vibe GT for my winter rims.
Re: (Sublimewind)
Posted: Mon Feb 16, 2009 12:53 pm
by vibolista
Hey if it works, it works!... but not really sure if I like the 55 Chevy tire to wheel well relationship. Couldn't you find some wheel spacers. H&R makes some. They are a pain, (extra 5 bolts per wheel) but will bring the wheel closer to proper offset.
Re: (vibolista)
Posted: Tue Feb 17, 2009 9:05 am
by Sublimewind
Quote, originally posted by vibolista »Hey if it works, it works!... but not really sure if I like the 55 Chevy tire to wheel well relationship. Couldn't you find some wheel spacers. H&R makes some. They are a pain, (extra 5 bolts per wheel) but will bring the wheel closer to proper offset.Old adage "if it ain't broke, don't fix it"
Subie rims
Posted: Tue Feb 17, 2009 10:49 am
by skeezix
Thanks, all! The 185 size improved traction in snow on a Legacy GT wagon.The Vibe has to be lighter than that...
Posted: Tue Feb 17, 2009 1:51 pm
by AKLGT
oh i'm sure it's a lot lighter than that. LOL, especially the older versions.
Re: Subie rims (skeezix)
Posted: Wed Feb 18, 2009 12:00 am
by Sublimewind
Quote, originally posted by skeezix »Thanks, all! The 185 size improved traction in snow on a Legacy GT wagon.The Vibe has to be lighter than that...I'm sure it IS lighter, but, do yourself a favor and put some bags of sand/corn/whatever in the back for some weight on the rear... I add 150lbs of corn to the back of the Vibe every year and it really settles the rear down on the highway..
