Anyone use Motorcraft 5w20 synthetic blend oil?
Posted: Sat Jan 31, 2009 9:24 am
by scooter
Seems pretty inexpensive compared to a lot of the oils out there. Wondering if anyone is using or has used it, and how they like it.
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (scooter)
Posted: Sun Feb 01, 2009 1:34 am
by djb383
Use Motorcraft 5W20 synblend in all 3 vehicles. Excellent oil, very good price.
Posted: Sun Feb 01, 2009 2:06 am
by Raven
I wouldn't use it in the '09 under warranty, might be an issue.
Posted: Sun Feb 01, 2009 5:10 am
by djb383
'09 Corolla's say 0W20 or 5W20.
Re: (djb383)
Posted: Sun Feb 01, 2009 5:50 am
by Raven
I wonder what the '09 Vibe is supposed to use? I assumed it would be 5W30 but maybe not.
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (Raven)
by scooter
Quote, originally posted by Raven »I wouldn't use it in the '09 under warranty, might be an issue.Why? Because it is a synthetic blend? I thought as long as the ASI standards were met by the oil used, and you still obey the intervals specified in the users manual, that would be ok?
Re: (Raven)
Posted: Sun Feb 01, 2009 5:52 am
by scooter
Quote, originally posted by Raven »I wonder what the '09 Vibe is supposed to use? I assumed it would be 5W30 but maybe not.5w20 or 0w20 - both are listed right on the oil cap.
Re: (scooter)
Posted: Sun Feb 01, 2009 6:10 am
by Raven
No problem then.
Posted: Sun Feb 01, 2009 7:52 am
by djb383
I believe Honda and Ford have recommended 5W20 for several years now.......and probably would prefer you use 0WXX since 0W is only availabe in synthetic.
Re: (djb383)
Posted: Sun Feb 01, 2009 7:58 am
by prathman
Quote, originally posted by djb383 »I believe Honda and Ford have recommended 5W20 for several years now.......and probably would prefer you use 0WXX since 0W is only availabe in synthetic.Toyota has also issued a notice that 5W20 is fine for the 1.8 l engines used in the older Vibes (and Corollas, Matrices, etc.) although they were originally specified to use 5W30 as shown on the filler cap and manuals.
Re: (prathman)
Posted: Tue Feb 03, 2009 10:42 am
by Digger
I am thinking of going 0w40 Synthetic for 10,000 Mile. in the 05 that will have 50,000 next change What do you all think?
Re: (Digger)
Posted: Tue Feb 03, 2009 1:24 pm
by prathman
Quote, originally posted by Digger »I am thinking of going 0w40 Synthetic for 10,000 Mile.Why the higher viscosity (40) rather than the Toyota recommendation for 20 or 30 weight?
Posted: Tue Feb 03, 2009 10:28 pm
by Sublimewind
I run 0w30 Castrol Syntec in my Subie.. It's the only oil on the shelves that is 100% German made, which holds them to MUCH stricter TUV standards... Running a 0wXX in the general car is totally not needed though... I use it so it flow into my Turbo quickly... It's also a vERY stable oil..
Re: (Digger)
Posted: Tue Feb 03, 2009 11:07 pm
by djb383
Quote, originally posted by Digger »I am thinking of going 0w40 Synthetic for 10,000 Mile. in the 05 that will have 50,000 next change What do you all think?Do what you want but here's some good reading from a pretty sharp fella that says thinner is better.
http://www.bobistheoilguy.com/aehaas/
Re: (djb383)
Posted: Wed Feb 04, 2009 12:09 am
by Digger
the ow-40 is what my new car is calling for. I am more concerned about the 10,000 mile interval. I change now every 5,000. The 10,000 is what the manual calls for in the new car.
Re: (Digger)
Posted: Wed Feb 04, 2009 12:28 am
by djb383
What new car calls for 0W40???????
Posted: Thu Feb 05, 2009 10:42 am
by SublimeVibe
I think the oil is for diesel engines.We ran 0w40 in our large trucks at work.They were stored outside at -40.
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (djb383)
Posted: Fri Feb 06, 2009 5:41 am
by Mojo72
I used the Motorcraft 5-W-20 in the 2006 Focus that I used to lease. As long as I bought by the case, I remember the price to be fairly reasonable.
Re: (prathman)
Posted: Fri Feb 06, 2009 2:26 pm
by NUBlackshirts
Quote, originally posted by prathman »Toyota has also issued a notice that 5W20 is fine for the 1.8 l engines used in the older Vibes (and Corollas, Matrices, etc.) although they were originally specified to use 5W30 as shown on the filler cap and manuals.According to the TSB, it is only approved for use in the 1ZZ-FE (Base/XR) engines, NOT for the 2ZZ-GE (GT/XRS).
Re: (djb383)
Posted: Sat Feb 07, 2009 11:58 am
by Digger
Quote, originally posted by djb383 »What new car calls for 0W40???????I am getting a Smart car. It comes from the factory and calls for 0w-40 every 10,000 mile. My wife will be driving the vibe for the most part. If I change the vibe to synthetic oil I will most likely extend the miles in between changes.
Re: (Digger)
Posted: Sat Feb 07, 2009 12:42 pm
by prathman
Quote, originally posted by Digger »I am getting a Smart car. It comes from the factory and calls for 0w-40 every 10,000 mile. My wife will be driving the vibe for the most part. If I change the vibe to synthetic oil I will most likely extend the miles in between changes.So why not use the lower viscosity that's recommended for the Vibe in the Vibe and the higher one in the Smart? I don't see any particular reason why you feel you have to use the same oil in both.Frankly I'm a bit surprised at the 40 weight recommendation for the Smart since it goes against the trend toward recommending lighter weight oils both for improved fuel efficiency and for better lubrication in today's engines that are made to stricter tolerances.
Re: (prathman)
Posted: Sun Feb 08, 2009 9:27 am
by Digger
I plan on useing the proper viscosity in each car. As far as the smart goes, I do not have it yet and I think the viscosity is dif. for west & south than it is for East & north
Posted: Wed Mar 10, 2010 9:45 am
by ColonelPanic
I finally have the ability to change the oil in our cars... Was out at mal*wart looking today for oil and found this stuff. I need 5w20 in the Hyundai and the shop I had been bringing mine to was a blend of some description and I kinda liked it... Motorcraft was the only blend they had in stock. You can't beat the price. $11.50 for the 5 quart jug. I seem to be reading good things about it so hopefully all goes well. What kind of life expectancy should I see with this stuff? I was doing 4k changes with the blend from the shop, I trust that would be ok here.
Re: Anyone use Motorcraft 5w20 synthetic blend oil? (ColonelPanic)
Posted: Wed Mar 10, 2010 11:53 am
by star_deceiver
Quote, originally posted by ColonelPanic » I was doing 4k changes with the blend from the shop, I trust that would be ok here. Should be fine, I see no reason not to do this if it's been working for you in the past!
