Fog Light Replacement - Suggestions
Posted: Wed Jan 28, 2009 2:59 am
by ihsn
Both my front fog lights are broken. The right one needs the housing as well. So I was looking for something like this:
http://cgi.ebay.com/ebaymotors..._1442Yay? Nay? or something better?Also the front (right) bottom grill is missing. Any places where to find one? Thanks a lot.
Re: Fog Light Replacement - Suggestions (ihsn)
Posted: Mon Feb 02, 2009 4:44 am
by ihsn
Anyone?
Posted: Mon Feb 02, 2009 6:10 am
by 2002sportside
What year Vibe? The fogs you link to will require some work to get them to fit, they're not a drop in.If you want a direct replacement,
http://www.partszoneonline.com/ has stock fogs for around $75 complete (not sure if it comes with the bulb). Or keep checking eBay for replacements.For lower grille, if eBay or a local junkyard doesn't have one, the same place sells them for about $18...
Posted: Mon Feb 02, 2009 6:18 am
by keithvibe
your better off with thesehttp://cgi.ebay.com/ebaymotors...A1318
Re: Fog Light Replacement - Suggestions (keithvibe)
Posted: Mon Feb 02, 2009 6:26 am
by 2002sportside
Quote, originally posted by keithvibe »your better off with thesehttp://cgi.ebay.com/ebaymotors...A1318I knew they had to be on there, just too lazy to look
Posted: Mon Feb 02, 2009 11:21 am
by CAN-AWD-VIBE
get the oem or oe replacement... then get covers, then put 9005 bulbs in them...
Posted: Mon Feb 02, 2009 11:48 am
by ihsn
Mine is '05, sorry should have mentioned this. Thanks guys!
Posted: Mon Feb 02, 2009 2:54 pm
by CAN-AWD-VIBE
that wont change the previous recommendations
Posted: Tue Feb 03, 2009 5:28 am
by Sublimewind
I'll throw this into this fog light post as well.... When I did a set for another member here, I had to swap the factory adjuster screws onto the new lights... I can't recall why now though... something about the pivot on the one end I think.... take one out and compare very carefully to make sure everything is the same..
Re: (Sublimewind)
Posted: Tue Feb 03, 2009 10:55 am
by vibe11
i thought 9006 went into the fog lights
Re: (vibe11)
Posted: Tue Feb 03, 2009 10:07 pm
by CAN-AWD-VIBE
Quote, originally posted by vibe11 »i thought 9006 went into the fog lightsthey do, but with a little mod the 9005 fit and are brighterthe 9006 has a frosted black "cap" on the end of the bulb- 9005 is all clearthey both work
Re: (CAN-AWD-VIBE)
Posted: Wed Feb 04, 2009 1:34 am
by bull77
Quote, originally posted by CAN-AWD-VIBE »they do, but with a little mod the 9005 fit and are brighterthe 9006 has a frosted black "cap" on the end of the bulb- 9005 is all clearthey both worki replaced my fogs with 9005 -- you can tell the difference and the mod takes about 30 secs...
Re: (bull77)
Posted: Thu Feb 05, 2009 4:01 am
by ramenboy...
Quote, originally posted by bull77 »i replaced my fogs with 9005 -- you can tell the difference and the mod takes about 30 secs... i think this will be the first mod of the new year, once it gets warm. my drivers side fog went out before th end of the year; been driving w/out the fogs since then.
