Smoothflow suppercharger pulleys - review
Posted: Tue Jan 27, 2009 10:17 am
by 4azdmunky
As promised here are some pictures of the pulleys i bought from Nate at smoothflowpulleys.comI bought a 2.1 and a 2.3 for a total of $150. It took a week to get them.So far,they look good. I'll post more after installing it. I'm thinking of going right to the 2.1 with the 2.3 for a spare.This first picture is of the kit. It included an allen wrench, 2 extra screws and instructions.
Re: Smoothflow suppercharger pulleys - review (4azdmunky)
Posted: Tue Jan 27, 2009 10:19 am
by 4azdmunky
This picture is of the top of the pulleys. It includes a hub with the 2.1 pulley and a 2.3 swappable pulley.
Posted: Tue Jan 27, 2009 10:20 am
by 4azdmunky
This picture is of the underside of the pulleys, once again the hub is mounted to the 2.1.
Re: Smoothflow supercharger pulleys - review (4azdmunky)
Posted: Tue Jan 27, 2009 10:21 am
by 4azdmunky
here is a picture of the ribs.
Posted: Tue Jan 27, 2009 8:32 pm
by kevera
When are you installing it??The only thing I hope is that they are balanced properly,because of the 2 piece design.I still ordered one though.Let us know how it goes.
Re: Smoothflow supercharger pulleys - review (kevera)
Posted: Tue Jan 27, 2009 11:25 pm
by Petrucci914
Ya, I wanna know how the install goes before I order one.Are the channels deeper, so that it is more of a non-slip design?If you go with the 2.3" do you still need to purchase a smaller belt?
Re: Smoothflow supercharger pulleys - review (Petrucci914)
Posted: Wed Jan 28, 2009 9:42 am
by 4azdmunky
The channels do look deeper, however it could be misleading as its polished and the factory is black. As far as I know, when using a 2.3, the stock belt will still work. I was going to install it tonight, but got out of work too late. I need to get it in before the weekend, going tubing up at Copper Mountain.
Posted: Fri Jan 30, 2009 2:10 am
by Celtic_Curse
Any updates?
Re: (Celtic_Curse)
Posted: Fri Jan 30, 2009 8:48 am
by 4azdmunky
Tired to pull the pulley tonight, but having problems getting the stock pulley off. Got dark, gave up, going to try again in the morning.
Re: (4azdmunky)
Posted: Fri Jan 30, 2009 8:53 am
by kevera
Getting the nut loose or just the pulley?
Re: (kevera)
Posted: Sun Feb 01, 2009 1:58 pm
by 4azdmunky
Getting the nut loose is causing the problem.Tried using an impact ratchet, tried twisting the belt to add resistance, tried bumping ignition with a ratchet attached, nothing worked. Did manage to stretch the belt so it slips now though.Any ideas on how to keep the pulley from rotating while taking off the nut? I really do not want to take the supercharger off again.
Posted: Sun Feb 01, 2009 10:08 pm
by Sublimewind
This may sound silly, but are you turning the nut the right direction? Things that spin like that are often reverse threaded, so the nut is always being tightened by the natural spin of the motor.. This could also be an instance like a strut, where you need a special socket with a cut out in the side to allow an allen wrench to be placed on the shaft to hold the shaft while the nut is broken free... (note, I know ZERO about the S/C, so, i'm speculating)
Re: (Sublimewind)
Posted: Sun Feb 01, 2009 10:15 pm
by kevera
I'm not sure which direction it comes off,but from what I remember it's not on very tight.You'll also need a puller to get the pulley off after,it's pressed on.
Re: (Sublimewind)
Posted: Sun Feb 01, 2009 10:58 pm
by 4azdmunky
didnt think about checking if its reverse threaded. I'll have to check that out tonight. I did try both directions and it just slipped. I wonder if magnason torqued it down when I sent it in for repair?
Re: (4azdmunky)
Posted: Mon Feb 02, 2009 11:03 am
by 4azdmunky
OK, got the pulley off today. It took one of those belt/strap wrenches to hold the pulley while taking the nut off. but....The new pulley's center hub is too short on the backside by 1/4 inch and the pulley rubs on the housing. I can put the pulley on backwards, and it works. I emailed Nate to find out about a replacement.
Re: (4azdmunky)
Posted: Mon Feb 02, 2009 11:06 am
by kevera
I guess I should have waited for you to install before buying one.I hope he hasn't shipped mine out yet.
Re: (kevera)
Posted: Mon Feb 02, 2009 11:19 am
by 4azdmunky
email him asap. That would suck if he did.
Re: (kevera)
Posted: Thu Feb 05, 2009 9:29 am
by 4azdmunky
I sent him my stock pulley and the hub for rework. Hopefully he can turn them around this weekend. Will post more as things develop.
Posted: Thu Feb 05, 2009 12:47 pm
by Celtic_Curse
Thanks keep us posted
Re: (4azdmunky)
Posted: Mon Feb 09, 2009 11:00 pm
by 4azdmunky
Alright, Nate emailed back. he said that he decided to make a new pulley to correct the offset. I'm not sure if this means new hub and pulley or a new pully that works on the same hub. i suspect its a new pulley that fits on a common center hub. The pulley is on the way back to me, I'll post new pics when I get it.
Re: (4azdmunky)
Posted: Tue Feb 10, 2009 12:02 am
by kevera
Nate said he's waiting for your results before he sends mine out.*Keeping fingers crossed* that everything works fine.
Re: (kevera)
Posted: Tue Feb 10, 2009 7:07 am
by 4azdmunky
Cool, it looks like its in MN, i would estimate getting it Thursday or Friday.
Re: (kevera)
Posted: Wed Feb 11, 2009 9:13 am
by 4azdmunky
Alright! The pulleys came in today. The 2.1 installed without any problems. I did use the one size smaller Gator Belt (4060840).The car spools 7 lbs @ 4K RPM, it used to max at 7 lbs @ 6500. It now maxes at 8.6 LBS @6500.The EGT is about 130 degrees hotter when cruising. Peaked out at 1450. This is with the snow injection spraying at 3200 RPM, so I might turn that down just a hair and see if that helps. see if I can get it to spray at 3K.The (removed)-dyno reported
Re: (4azdmunky)
Posted: Wed Feb 11, 2009 9:16 am
by 4azdmunky
Now,........i need to figure out how to blow my engine again so I can go for that 1zz from MWR.
Re: (4azdmunky)
Posted: Fri Feb 13, 2009 4:56 am
by Petrucci914
haha, nice!So if I order the 2.3" from him, he should have it all figured out now?
Re: (Petrucci914)
Posted: Thu Feb 19, 2009 7:13 am
by kevera
I got mine today.I have to say,they look real nice.I went with a machined finish and quality looks great.Install will be this weekend.
Re: (Petrucci914)
Posted: Thu Feb 19, 2009 1:06 pm
by 4azdmunky
Yeah its working great, worth the time investment of having my car down for a week.
Re: (kevera)
Posted: Thu Feb 19, 2009 1:07 pm
by 4azdmunky
Sweet! let me know what you think after running with it.
Posted: Fri Feb 20, 2009 7:22 am
by Smoothflow
I'm certainly glad you guys like it! I've got the correct dimensions now so anyone else interested can pm me.Thanks,Natehttp://
www.smoothflowpulleys.comsales@smoothflowpulleys.com
Re: (Smoothflow)
Posted: Wed Feb 25, 2009 4:07 am
by Petrucci914
With the 2.3" can you use the stock belt, then?
Re: (Petrucci914)
Posted: Wed Feb 25, 2009 4:28 am
by kevera
Yep,stock belt.
Re: (kevera)
Posted: Tue Jun 23, 2009 8:21 am
by Petrucci914
Quote, originally posted by kevera »Yep,stock belt.Finally got mine! 2.3"Now to do the install.....Words of wisdom?
Re: (Petrucci914)
Posted: Wed Jun 24, 2009 9:48 pm
by 4azdmunky
Loc-tight!...LOL I ended up re-adjusting the pulley shims, however I went to 2.1, with disabling the bypass valve and got it up to 10 lbs.
Re: (4azdmunky)
Posted: Fri Jun 26, 2009 4:36 am
by Petrucci914
What's the Torque Spec on the nut?
Re: (Petrucci914)
Posted: Mon Jun 29, 2009 6:40 am
by 4azdmunky
uhmm.....as far as I could tighten it Had to use a strap wrench to keep the shaft from spinning, and tightened it until it spun in the strap wrench.
