rear brakes
Posted: Fri Jan 23, 2009 10:30 am
by thebutch
Hi:I have a 2005 Vibe with about 65,000 miles. I have not changed the front or rear brakes. I have a scraping noise coming from the rear brakes only when they are applied. I have pulled the drums and there is plenty of thickness on the shoes. This noise seems worst when the vehicle is cold and or it is cold outside. Awhile ago my brother in law borrowed the car, and rode with the emergency brake on. I had heard that this can cause the brake shoes to become glazed. The noise seems to be a common topic on this forum. Is it something that I should just deal with, because it is normal? Should I just change the shoes? Am I missing something? Thanks, Dante
Posted: Fri Jan 23, 2009 10:48 am
by ou.grizzly
Get your vehicle to a shop and get the issue fixed. At the same time, kindly sent the bill to your brother-in-law.
Re: rear brakes (thebutch)
Posted: Fri Jan 23, 2009 10:55 am
by keithvibe
if it's indeed a glazing. get 1000grit sandpaper and sand it off.but a new set of pads are so cheap, I would change them out
Re: rear brakes (keithvibe)
Posted: Mon Jan 26, 2009 2:27 am
by Sublimewind
Quote, originally posted by keithvibe »if it's indeed a glazing. get 1000grit sandpaper and sand it off.but a new set of pads are so cheap, I would change them outyou mean 100 grit?? 1000 is quite fine... I usually use 50 or 80 grit..
