Wind leak...
Posted: Fri Jan 23, 2009 10:27 am
by capecodbeachfront
I would like to put a heavier weather stripping on the INSIDE of the door where the glass pushes against it. Top of the bottom half of the door. What is this part called?? Is there a heavier version available. Wind noise is coming up the inside of the glass... passenger side.
Re: Wind leak... (capecodbeachfront)
Posted: Fri Jan 23, 2009 10:50 am
by ou.grizzly
I do not think anything is available for that or will work properly because once you roll the window up/down, there will be issues.
Posted: Fri Jan 23, 2009 11:32 am
by keithvibe
do you have vent visors? if not you may want to try those to help deflect the air away from the window
Posted: Fri Jan 23, 2009 11:46 am
by lowincash
i stuffed some thin weather strip foam in my front window channel and it helped cut down some wind noise.
