hid
Posted: Tue Jan 20, 2009 12:04 pm
by vibe11
where is a good place to buy hid's online?
Posted: Tue Jan 20, 2009 8:09 pm
by Wolfman213
if you want things "proper" wait till keith does the group buy again and do a retrofit. The kit in the GB had both bulbs, ballast, projectors and even sealant. The only additional thing you needed was extra wire for the angel eyes. Other than that, tons of places are going to be different and it's basically first hand experience on whether a place is good or not. I've got two sets from HIDKing on ebay and plus a buddy got a kit from them as well and they have been excellent. Super quick shipping and great product.
Re: (Wolfman213)
Posted: Tue Jan 20, 2009 11:12 pm
by Whelan
If you can find a good vendor on Ebay. That;s where I got my Xentec
Re: hid (vibe11)
Posted: Wed Jan 21, 2009 12:24 am
by Amtron
Quote, originally posted by vibe11 »where is a good place to buy hid's online?I have some for sale:http://forums.genvibe.com/zerothread?id=35883
Re: hid (Amtron)
Posted: Wed Jan 21, 2009 1:29 am
by vibe11
i need 9007 for my friends car. but for my car im looking for both hi and low beam. good luck with the sale amtron
Re: hid (vibe11)
Posted: Wed Jan 21, 2009 1:33 am
by Amtron
Quote, originally posted by vibe11 »i need 9007 for my friends car. but for my car im looking for both hi and low beam. good luck with the sale amtron Thanks!
Re: hid (vibe11)
Posted: Wed Jan 21, 2009 3:48 am
by NascarXprt
vibe11 you can use Amtrons HIDs for your low beam fog lights!
Posted: Wed Jan 21, 2009 3:55 am
by Wolfman213
Are you sure? The wiring harnesses should be different since Amtron's kit is for the 9003/H4 connection and the fogs being the 9006.
Re: (Wolfman213)
Posted: Wed Jan 21, 2009 4:01 am
by Amtron
Cole's right. All you need is a different bulb I believe. Where's Keith, he knows everything about this stuff. It's either the bulb or conversion, but I believe it is the bulb.
Posted: Wed Jan 21, 2009 4:11 am
by Wolfman213
My bad. I figured that since before you were using the H4 factory connection to connect to your ballast that it would not be compatible to the 9006 factory connection that would connect to your ballast.
Re: (Wolfman213)
Posted: Wed Jan 21, 2009 4:33 am
by NascarXprt
i think so, i wasnt sure which HID Matt had.
Re: (Whelan)
Posted: Fri Jan 23, 2009 1:50 am
by Sublimewind
Quote, originally posted by Whelan »If you can find a good vendor on Ebay. That;s where I got my Xentecyeah, aren't you having problems with those....
Re: hid (vibe11)
Posted: Fri Jan 23, 2009 6:36 am
by keithvibe
Quote, originally posted by vibe11 »where is a good place to buy hid's online?from me... check my siggy.
Posted: Fri Jan 23, 2009 7:26 am
by Celtic_Curse
Do you need to disable the DRL to use the HID's?
Re: (Celtic_Curse)
Posted: Fri Jan 23, 2009 7:49 am
by keithvibe
Quote, originally posted by Celtic_Curse »Do you need to disable the DRL to use the HID's?Yes or you can add a resistor, to have your lights come on full power at start up.Disabling is a better option to save bulb life.
Posted: Mon Jan 26, 2009 12:47 am
by Celtic_Curse
Thanks, noted.
