Looking for a bolt...
Posted: Tue Jan 20, 2009 12:23 am
by BlueCrush
It is for the bottom mount of the intake manifold on the 1ZZ. If anyone can tell me any info about it: Size, thread or better yet, a part#. I would greatly appreciate it. Thank you.
Re: Looking for a bolt... (BlueCrush)
Posted: Tue Jan 20, 2009 12:35 am
by kevera
I know it has an 8mm thread,because on the s/c that's where the support bracket sits.(the replacement bolt is 8mmx45mm-which is longer than stock)Wish I had a part # for ya.
Re: Looking for a bolt... (kevera)
Posted: Tue Jan 20, 2009 5:05 am
by BlueCrush
Thanks, Kev. I'll keep that info in mind if I have to go to the hardware store to find a replacement. In the meantime, while I'm waiting for my gasket set to arrive, if someone knows a part#, please post it up.
Posted: Tue Jan 20, 2009 8:22 am
by BlueCrush
Got a Toyota part# from Dominator on 9thGenCorolla. 90119-08908Cost: $1.55
Posted: Mon Jan 26, 2009 10:52 pm
by BlueCrush
I picked up the bolt and installed it last night. This morning my idle was pretty rough until the engine warmed up. I tightened it by hand and might have made it too tight. I'm guessing this is the idle hunting issue. I'll see if it does it again at lunch then loosen the bolt a little to see if that helps.
