Fan Switch Works on High Only
Posted: Wed Jan 14, 2009 5:44 am
by ric36012
The 3-speed fan switch on my '05 Vibe operates only on the "high" setting. Has anyone else had a similar problem? Thanks.
Posted: Wed Jan 14, 2009 5:58 am
by Sublimewind
It's a somewhat common problem, you likely need a new fan resistor, which is an EASY fix, there is plenty of into here about it... Check the DIY sections stickied to the top of the pages.. Mine a 4 position, only works on med/high and high ATM...
Re: Fan Switch Works on High Only (ric36012)
Posted: Wed Jan 28, 2009 1:12 pm
by slasababy
did you get that fixed yet when it happened to me it was because of a rodent in the venting and it messed up my fan blades
Re: Fan Switch Works on High Only (slasababy)
Posted: Thu Jan 29, 2009 8:43 am
by 2002sportside
I'm willing to bet it's the fan resistor, the rodent sounds like a freak occurrence. $7.16 at Toyota World...
