headlights come on with car parked?
Posted: Sun Dec 21, 2008 11:05 pm
by jme2565
This latest snow in michigan unearthed a new problem with my GT, the headlights were on when I got up that morning. I could not get them off. I thoughtmaybe a sensor was bad and parked it in the garage which was about 45F. after it warmed from the single digit temps to garage temp the lights went off. 2 days pass. I park it back outside for the first time since then and again, LIGHTS ON! This time...Dead battery. HELP?
Re: headlights come on with car parked? (jme2565)
Posted: Thu Jan 08, 2009 5:43 am
by msu90
Is your car a 2003? There are a couple of discussions of this problem with some of the 2003 models. The best way to make sure the lights don't come on is to put the high beams on at night. I haven't been able to get anyone to fix the problem, so I just put my high beams on at night. It seems to only happen when the temps dip below 20F.
Posted: Fri Feb 06, 2009 1:14 am
by aliensurfer
I was checking around for this exact problem for a friend of mine and came across this TSB. Hope it helps.
Attached files T-EL003-03.pdf (24.4 KB)
