04 Vibe Driver Door Master Window Switch Panel Trim
Posted: Fri Dec 19, 2008 7:19 am
by Tarfu43
The plastic trim assembly around the drivers side master window switch panel had the lower tab break off, so the entire panel is loose. The dealer wants $60 for this hunk of plastic! Is there an online dealer that sells these at a reasonable price? Napa maybe?Thanks in advance!
Re: 04 Vibe Driver Door Master Window Switch Panel Trim (Tarfu43)
Posted: Fri Dec 19, 2008 8:15 am
by zionzr2
you try the Toyota dealer?or junk Yard?
Posted: Fri Dec 19, 2008 10:36 pm
by JohnC
auto salvage yards usually charge 50% of the price of a new part. can you fix it yourself?...maybe some epoxy.
Posted: Fri Dec 19, 2008 11:43 pm
by ou.grizzly
Pontiac. Toyota will want over $300Replaced 2 already in the 150,000 + miles
Posted: Sun Dec 21, 2008 11:26 pm
by Tarfu43
I'll probably try and fix it, although it may be a challenge, as the plastic tab that broke off is missing. I'd sure hate to go crawling back to the Pontiac dealer hat-in-hand to order another one. (They already ordered me one before, but I refused to take it because I was apalled when I found out the price. I didn't ask before ordering, since I assumed it would only cost $20 or so. Hey, it's just a hunk of plastic!)
