How Can I turn The Headlights Off?
Posted: Thu Dec 18, 2008 8:10 am
by immortalight
I have a new (used) 2006 Vibe. Today it was foggy and I wanted to drive with just the running lights on. How can I do this? I didn't find anything in the manual about this. it can be dangerous to drive in some fog with headlights on, how do I keep the headlights from turning on every time I start the car? What if my battery were low and I needed to drive around to re-charge it? I wouldn't want the headlights on?Can anyone help me with this?Also the seat belt alarm is driving me crazy! I can't put my backpack in the seat beside me without buckling it in or the alarm goes off. It'sS O annoying. Has anyone found a hack for this? Is it a fuse you can pull out or a wire you can cut? Thanks!Morgan
Re: How Can I turn The Headlights Off? (immortalight)
Posted: Thu Dec 18, 2008 8:33 am
by keithvibe
check the DIY section you will find both your answershttp://forums.genvibe.com/zerothread?id=25918
Re: How Can I turn The Headlights Off? (keithvibe)
Posted: Thu Dec 18, 2008 8:40 am
by immortalight
Thank you!
Posted: Fri Mar 13, 2009 2:45 pm
by skillz305
this guy said he will disable it for me and put a switch for 40 dollarsis this a good deal ?
Re: (skillz305)
Posted: Fri Mar 13, 2009 10:30 pm
by zionzr2
You can do it your self and save about $35. the how-to walk troughs make it pretty easy.All you need is a switch and a way to cut a wire.
