Front Sway Bar Installation w/ pics
Posted: Sat Apr 26, 2003 5:58 am
by cohocarl
*****This is a step-by-step explanation on how I installed my front sway bar. The process involves removing and re-installing significant structural and steering components on the car. Incorrect re-installment of these components could lead to steering failure, and result in serious injury to yourself and others. IF YOU ARE NOT COMFORTABLE WITH YOUR ABILITIES TO CORRECTLY (AND SAFELY) RE-ASSEMBLE YOUR CAR, TAKE IT TO A SHOP AND HAVE THEM DO IT!!!***** I did my own front sway bar install this A.M. It does take alot of time, but it actually was easier than I thought it would be.First I loosened up the lugs on the wheels then jacked up the front and put it on jack stands, removed the wheels (and put under the car by the jackstands so if the jackstands fail....)My Vibe is a 5-speed without ABS, so yours may have more garbage to work around.I had read in a post that some people (including myself) was worried that the motor would need support from above, but it does not. You are removing bolts that hold a lower engine mount, but the remaining mounts hold the motor & tranny fine.The first thing I did was look everything over, (including the instructions, but they aren't that helpful, pics are awful),and removed the 3 bolts and 3 nuts towards the middle of the "cradle". (see below)After the above bolts/nuts removed, place a floor jack under the center of the cradle. Bring jack up close to the cradle, but don't put any pressure on it, you're only going to use the jack to lower the cradle.(NOTE: Below, the Hotchkis instructions say to remove these 3 bolts/nuts on each side, but I have done this job twice without removing these bolts/nuts. Makes the job quicker if you don't. Just don't lower the lower cradle any further than you need to.)Remove the 3 bolts/nut at the bottom of the spindle/lower suspension arm.Now the most difficult part for me was loosening up the 4 bolts that hold your steering rack down to the cradle. These are accessed from above the cradle. The two on the passanger side, I removed from the engine compartment with 2 very long extensions, the driver's side front was the difficult one to get at. I believe these are also 17mm.You only need to loosen the bolts up all the way out of the threads, but you don't need to bother removing them.These two bolts on each side are very tight. An air impact wrench will be much safer to remove these bolts than a ratchet with a "cheater bar" because you could pull the car off of the jackstands. I have a wimpy air gun that wouldn't loosen one of them that I did carefully loosen with a ratchet. I loosened all 4, then removed the upper/more forward bolt on each side. These bolts are the only thing remaining holding up the cradle, so I loosened the rear bolts a ways, then lowered the jack a little to see if everything was clearing. I then removed the rear bolts and lowered the cradle just enough to easily get at the 4 bolts that clamp down the sway bar, removed them, and then the bar. The passanger side of the bar snakes between a couple power steering hoses, so you need to be careful when removing/re-installing the bar. I pulled the driver's side back out of the way, then snaked the passanger's side out of the power steering hoses.The Hotchkis instructions have a picture of the sway bar installed under this power steering hose. The stock bar was installed OVER this hose. I attempted to install like the instructions showed, but it would not fit, so I put it over the hose like the stock one was, and it fits fine.I just installed the new bar in reverse order. The Hotchkis bar has two holes in each end of the bar which are two different "stiffness" settings. I put it in the rearward, inner hole which is the stiffer setting.I was worried I'd have problems with the cradle not aligning up with everything, but I didn't have any problems. Everything bolted up just fine. I re-installed everything finger tight, then went back and torqued them down. REMEMBER TO TIGHTEN EVERYTHING BACK UP!! I torqued all the nuts/bolts to what the instructions indicated. (with exception to the driver's side forward steering rack bolt. It's close enough...)I took the Progress rear bar off and put on the Hotchkis bar to keep everything balanced. See http://forums.genvibe.com/zerothread?id=1153 for a rear bar install.I've only took it for a few mile drive, but it seems to REALLY improve the handling of the car. Most of my daily driving is on I-75, and I was very disappointed with how the car got tossed around by the wind. It's a little windy today and I didn't even notice it, other than hearing it. This car should handle like this from the factory. Will post a follow up after I have a chance to drive it more.If you are thinking of doing it youself, and you are pretty good with a wrench, I wouldn't be too afraid of tackling it. It does take alot of time. I started at 10am, and came in to get cleaned up after changing both bars at 1:45pm. If you don't have some decent jackstands, floor jack, or a safe, level, concrete place to work on it, I wouldn't recommend it though. I have an air compressor and an air impact gun which speeded up the job alot. Take your time, and work safe. Don't forget the safety glasses also.Carl
Re: Front Sway Bar Installation w/ pics (cohocarl)
Posted: Sat Apr 26, 2003 6:53 am
by rasermon
Good job done and great post. Coho, sorry I wasn't around to give you a hand with your install. Was down state helping TritonGT install his CAI.
Re: Front Sway Bar Installation w/ pics (rasermon)
Posted: Sat Apr 26, 2003 6:57 am
by cohocarl
quote:Good job done and great post. Coho, sorry I wasn't around to give you a hand with your install. Was down state helping TritonGT install his CAI.The wife took the boy down to her mother's this a.m., so I thought I might as well give it a shot while I had the time. Let me know the next time you are heading over this way and you can take it for a spin and let me know what you think.Carl
Posted: Sat Apr 26, 2003 9:49 am
by Lorin
Wow! This post rocks! Makes me (almost) feel like doing this myself! I think I may still let that local speed shop do it for "a bill and a quarter" (They all talked with their hands like on supr-tunr tv!). While they do the work, I'll sit in their (very nice) waiting room and prepare for a network install (billable hours to the customer of course! ) I'll come out ahead of the game financially while keeping my eye on them as they work.Cohocarl - did you have any trouble getting the u-shaped brackets with the bushings mounted back on the car? The speed-shop said they had trouble on the last one they installed.
Re: Front Sway Bar Installation w/ pics (Lorin)
Posted: Sat Apr 26, 2003 10:18 am
by cohocarl
quote:did you have any trouble getting the u-shaped brackets with the bushings mounted back on the car? The speed-shop said they had trouble on the last one they installed.None. I put on a little of the grease they supply, and the polyurethane bushings slipped over the bar fine, and the u-shaped bracket fit bushing and the mounting holes fine.
Posted: Sun Apr 27, 2003 12:28 am
by Hawke
Excellent Post! This post made me add a pole to the suggestions for genvibe. This is one of the best posts on genvibe and I thought that it should be put into a different section that is more visible so that it can be referenced more. I think it would improve genvibe by gathering these first hand, well documented posts into one area. Hopefully only a moderator would be able to move the posts there. http://forums.genvibe.com/zerothread?id=3799
Re: Front Sway Bar Installation w/ pics (Hawke)
Posted: Sun Apr 27, 2003 12:38 am
by rasermon
I agree with you Hawke. I'm sure Nick or Derek will make this a sticky. OT: Cohocarl would make a excellent moderator for this forum (Handling, Suspension & Brakes).
Posted: Sun Apr 27, 2003 1:23 am
by nfrosty
Exellent post. Wish it would have been up before I started installing my front bar. Would have saved me some time. Your right the instruction from Hotchkis are weak at best.One suggestion though. I found it much easier to get the rack and pinions 4 bolts off if you disconnect the 2 end bolts of the sway bar first. This allows the sway bar end to pivot up and down making it a little easier to get at the steering bolts behind it.
Re: Front Sway Bar Installation w/ pics (silverawd26)
Posted: Sun Apr 27, 2003 7:01 am
by cohocarl
If someone brings out some decent struts, I may invest in them and some springs, but it seems to be fine for now. I just took it down to Menards with a 4x8 trailer and picked up a new sandbox and 200lbs of sand and it handled great.
Posted: Sun Apr 27, 2003 9:44 am
by Lorin
Only three days remaining on the current sale Hotchkis has going on and I'm still undecided.....Cohocarl - let us know how it works on the x-way.... if its a "little" better, "somewhat" better... or "killer!!! " ....
Posted: Sun Apr 27, 2003 9:48 am
by cohocarl
quote:Only three days remaining on the current sale Hotchkis has going on and I'm still undecided.....Cohocarl - let us know how it works on the x-way.... if its a "little" better, "somewhat" better... or "killer!!! " ....O-Tay! I'll post A.S.A.P. I'd like Rasermon to take it for a spin for a 2nd opinion also.
Posted: Sun Apr 27, 2003 10:25 am
by cohocarl
quote:I know I was impressed with his GT and CAI he installed. Sounds pretty sweet doesn't it
Posted: Sun Apr 27, 2003 10:50 am
by Vibe
Very well done job not only on your Vibe but a great post as well.I would recommend that you have your wheel alignment checked since everything was disturbed from the factory set position.At my automobile plant (Cadillac) .Whenever a cradle is dropped for an after build problem or repair --the car always goes to be Re Toed.Because everything does have a little leeway slop.I hope to talk to you personally and see your job at the Michigan get together. James
Re: Front Sway Bar Installation w/ pics (Vibe)
Posted: Sun Apr 27, 2003 5:45 pm
by cohocarl
quote:I would recommend that you have your wheel alignment checked...Yes, I thought about that. You are removing and re-installing the framework of the front of the vehicle, and it could change the alignment when re-installed.quote:I hope to talk to you personally and see your job at the Michigan get together. JamesI'm on mandatory O.T. at work, trying to get my house fixed up so we can list it for sale, purchasing a new house, AND a very active 19 month old boy, but I've already discussed the meet with my wife and she's O-tay with me going. I'm looking forward to meeting everyone also.
Posted: Tue Aug 05, 2003 5:28 pm
by Psychobroker
Sorry to bump and old thread, but it's an awesome reference tool (thanks again cohocarl). Mods should sticky this post. Unfortunately, none of the images came out...do you still have them somewhere coho? thanks again. This makes 2 DIY posts of yours I intend on using, starting w/ your speaker install this weekend
Re: Front Sway Bar Installation w/ pics (Psychobroker)
Posted: Tue Aug 05, 2003 5:55 pm
by cohocarl
quote:This makes 2 DIY posts of yours I intend on using, starting w/ your speaker install this weekend Thanks, glad they come in handy!I don't know why the pics aren't coming through on your end, they seem to be coming through fine here. Could have been a temporary problem with the server they are on.(?) Still not seeing them?
Posted: Fri Nov 02, 2007 1:37 am
by JSart
I know this is an old thread, but it helped me with my front sway bar install last night. Took a little more then 2 hours, but hey I'm slow. Results - great. Car rides better even in a straightline. Cornering is up and more stable. More noticable control. GM should sorce out these bars for every car. Installed the rear bar the other day but the real difference is felt after one installs the front bar. Thanks for all you help on the thread.Joel
Posted: Wed Oct 06, 2010 10:53 am
by StephenC
Wow, thanks for the post. An amateur like me can do this by myself. Thanks man, keep posting instructions that amateur like me can easily get it like this post for Sway Bar.
Posted: Sun Aug 04, 2013 6:35 pm
by davhamm
Anyone know if these are still available somewhere?
Posted: Wed Jul 20, 2016 9:27 am
by RustyIndian
Hey guys, newbie to forum, great stuff and thanks for sharing this daunting job!
Question --- my rusty and dusty Vibe is slowly (as my deflated wallet allows) coming back from the previous owners neglect -- the sway
bar install caught my eye -- is it possible to sneak in new bushings (not including the bar removal) with out dropping quite so much of
the engine cradle?
Thanks big --
Posted: Fri Jul 22, 2016 12:42 pm
by jolt
Yes, the inner stabilizer bar bushes should be slit on the side and can be removed from the bar and new ones install. This is shown in the factory manual.
Posted: Fri Jan 06, 2017 6:57 pm
by DSChamber
Hey guys.... sorry for digging up an old thread but I was wondering if I could get some clarification...
I want to replace the sway bar bushings on my '05 .... just wondering if I can remove the u-brackets and slip in a new set of bushings without dropping the cradle? I know that the new bushings are split so they can slip on over the bar and be put in place, just wondering if there is enough room to get at the 4 bolts that hold down the u-brackets? If the cradle has to be dropped then so be it, but if it don't then that would be MUCH easier :lol:
Thanks in advance to anyone that can help me out before I start jacking things up.... I have been a long time browser of this great forum and have picked up many many tips along the way. I own a '07 and a '05 Vibe (fwd base models) and have done almost all of my own work on these cars!
